Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Installation & Station Setup
Amateur Callsign Lookup
Enter Callsign:
Coax length.. does it matter or not
Like Tree5Likes
Reply
  #1
Old 03-28-2012, 07:06 PM
Senior Member
dxing440 is on a distinguished road
Default Coax length.. does it matter or not
I run a magnum s45hp radio ( turned down to 2Wdk and 35Wpep) with 6' rg8x to the dx500v,gives me (80Wdk and 400Wpep)and 12' of rg8x to the antenna, roadtech open coil, mounted on pass side about 8'' from cab and the bottom of the coil is about 3' below the cab.
EVERYTHING is grounded to the frame, as short as it can be.
The swr are at 2.1-2.7 with amp on, but just with radio @2Wdk the meter will not adjust over far enough to test swr.
The radio at 15Wdk and 80Wpep the swr's are about 1.3
WHAT GIVES?
  #2
Old 03-28-2012, 07:36 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
Coax information
  #3
Old 03-28-2012, 07:37 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
Quote:
mounted on pass side about 8' from cab and the bottom of the coil is about 3' below the cab.
It is " inches, not ' feet
As long as you continue to run that antenna 8 inches away from the cab of your pick-up truck, i think you are going to have a problem.
You need get that antenna away from or above the cab or it is just gonna drive you crazy.
The Coil of that antenna is below the level of the roof it is even worse.
This is the worst place to mount a loaded antenna , even more so with the LOAD ( the COIL) mounted below the roof
I really recommend the Wilson 5000 Mag mount, and stick it up on top of the cab.
You are gonna pay 85 or 90 bucks for a Predator and if you stick it in the same place i bet you will have the same problem.
Robb likes this.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/eit_171/512/latest.jpg
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #4
Old 03-28-2012, 07:41 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
And if you keep smakin' that amp with 80 watts input - it will fry too. The Texas Star amp repair guy is a member of this forum - BTW. He said the most common reason for failure with their amps are people trying to get more watts out of the amp by putting too many watts in. Of course; ya don't have to take my word for it . . .
hookedon6 likes this.
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #5
Old 03-28-2012, 07:49 PM
Default
Move the Antenna away from or above the cab
Look at this Picture, if you have to mount the antenna behind the cab It SHOULD look like this:
__________________
Radio-active
NASA/SOHO
When I was a child
The child is grown,
The dream is gone.
  #6
Old 03-28-2012, 07:56 PM
Senior Member
Default
Hey bootymonster, good info on the coax. Although, I just cant understand how to calculate the half wave, full wave, thing for 11 meters or any meter. LOL
And audio, ive heard the antenna suggestion more than once, wilson 5k must be a good one. I just dislike magmount antennas, but its that, or keep a huge bottle of asprin, for the coil antenna.
Thx
  #7
Old 03-28-2012, 08:00 PM
Senior Member
Default
hey robb if you read my 1 post again, its at 2wdk and 35pep NOT 80
  #8
Old 03-28-2012, 08:10 PM
Robb's Avatar
Yup
Default
Quote:
Quote:
. . . The radio at 15Wdk and 80Wpep the swr's are about 1.3 . . .
Just sayin' man . . .
First off, just run as much coax as you need to make it from point "A" to point "B". With just a couple extra feet of wiggle room for good measure. Forget about all of that BS about how long a piece of coax needs to be. Get yourself a Predator antenna, use a puck mount and cut the sheet metal in the center of the roof of the cab, run some LMR-240UltraFlex/RG-58 coax, and be done with your SWR problem. Or a mag mount Wilson 5000 too . . .
BTW - if you run more than the Texas Star recommended power into that amp (20 watts/25 max), you will defeat the AB class amplification you bought that amp for.
AudioShockwav likes this.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
Does coax length really matter when tuning? 53 bayous CB Antennas 45 04-03-2011 05:36 AM
Common Mode Currents Sonwatcher General CB Services Discussion 3 07-30-2008 08:45 PM
Adjusting SWR with amp T-bone CB Antennas 59 03-27-2008 06:48 PM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
Powered by vBulletin®
