WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > Installation & Station Setup
Notices
Installation & Station Setup General installation help & tech tips for mobile or base operations.
Reply
  #1 (permalink)
Old 10-21-2007, 03:29 AM
vnsdeacon
Guest
Posts: n/a
Default deadkey change
I have My stryker 4400 in My ram 1500. Pluged into cigarett lighter. With power all the way up it shows 12watt dk. I ran the power to the battery. I also put in my texas star 250. Now heres the problem I only get a 5watt dk with the amp not even on. Im only going to run 3 watts into the box.They are running of the same power leads.Could that be the problem.I am still using my lil'will for now. Did I miss something :?:
  #2 (permalink)
Old 10-21-2007, 07:47 AM
King Mudduck's Avatar
Senior Member
King Mudduck is an unknown quantity at this point
Default Re: deadkey change
Quote:
You need to have the power separate for the amp and the radio and also separate grounds as well. You should also throw that little will out and move up to a larger Wilson mag mount. Those little will's are only good for 300 watts and dont work that well to begin with.
You do know that with that radio swinging to 40 or 50 watts that is way to much drive for a 250 watt Texas Start dont you? Dont be suprised if you start blowing pills in your amp!
__________________
Forget the Democrat VS Republin argument. Both parties are destroying this country, WAKE UP PEOPLE!!!
  #3 (permalink)
Old 10-21-2007, 04:45 PM
vnsdeacon
Guest
Posts: n/a
Default
Im going to run the radio of the cig. lighter. Can I turn the Var.power down or do I have to send it back to the shop. Like I said Im only going to run 3 watts into it.
I used to run the amp. With my 29 with 3watts in to it.
I am looking at a 10k or just using my t-2000.
  #4 (permalink)
Old 03-25-2008, 06:16 PM
minitrucker's Avatar
Senior Member
minitrucker is on a distinguished road
Default
why does the power wires have too be separate? i run my radio off the amp power and ground and my stuff works fine ?
__________________
uniden 68xl cobra 450xl wilson 2000 on my mini
connex 4600 turbo as base with pt99
lotsa other toys on the shelf
400 watts and you lock down on am around here !
10k's are coming soon ! thanks 555
  #5 (permalink)
Old 08-19-2008, 01:04 PM
9C1Driver is on a distinguished road
Default
A Stryker 440 is a pretty hot radio for a Texas Star 250. That amp will need a 1.5-2 watt input dead key and probably no more then say 25-30 watts peak swing. The radio will have to be re-tuned alittle.
As stated your antenna needs to go. Use a 6 foot jumper, make sure the grounds and over-all instalation is in order. If your SWR is good your ready to talk.
  #6 (permalink)
Old 09-04-2008, 06:38 PM
Senior Member
moleculo has disabled reputation
Default
Use a barrel connector on the coax to bypass the amp and see what happens with your power output. If the power output is normal, then the problem is obviously the amp, which means that the input of the amp is not at or close to 50 ohms and the radio is reducing the output power because of it. You could also verify this by just using the SWR meter built into the radio to measure your swr. It would be helpful if you performed that test with a dummy load, unless you're REALLY certain your antenna is OK.
  #7 (permalink)
Old 09-04-2008, 09:56 PM
Rf Engineer
freecell is on a distinguished road
Default
the Stryker 440 can be matched perfectly to drive a TSDX250 and unless you want ground loops and other nasty stuff to contend with you need to skip the cigarette lighter plug crap and connect both the amplifier and radio to common B+ and chassis ground terminals using the shortest wire lengths possible.
connecting power to the radio and amp using separate voltage sources is a good way to guarantee ground loop problems. a three watt carrier level is excessive input for a DX250.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
