im ot being a smart arse here at all, but why would you need to solder it ,if it says solderless ??
and you say you cant depend on it makeing a good contact , i slid the center of the coax all the way threw the tip of the connector and the cut it just above the tip then folded it over seeings how there is nylon inside i figured it would make great contact, and again the conecters say solerless , so i just figured they would be fine,,, i guess ignorance is the easy part of this hobby ..
as a side note , the mass does not go all the way in ( sorry if i made it seam that way ) but i can move the cable around easily and also hear it moveing around inside the pipe when i jiggle the outside cable ...
(You need to get a good book and some insurance.) i have many books ( just too bad there not about cbing ) and i have great insurance. lol
but again like i siad i dident do anything permanent beacuse i do want to move the antenna higher , i just dident want to mount it all the way up there if i was just going to have problems ...
there is a shop around here , i will take the radio there , but what is weird is that last night wile on the radio that seams to not calibrate , i seamed to talk fine in the mobil setup , only a few miles , but that was on a Wilson 1000.
ok , tomorrow i will take down the antenna , check the coax for any areas that might have been damaged , and cut to correct length ,, solder the center pins .
but i want to ask this ! it seams that the second radio is tuneing fine . do you guys just think im getting lucky at the moment or are the readings i posted earlier not like they should be .. yes even if they are like they should be i will be changing the set up ...
also i never was like screw it this is good enough ( about the set up ) , i just diffident get reception with the antenna low to the ground , so i was worried the antenna wasn't a good one , so i temporarily thew it on the roof to see if i could get a better signal . ignorance is bliss
