Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Installation & Station Setup
Amateur Callsign Lookup
Enter Callsign:
window pass through
Reply
  #1
Old 09-27-2010, 06:05 PM
bluestallion is on a distinguished road
Default window pass through
I'm looking for something like the MFJ adapter that lets you run your coax through window. But not wanting to spend that much. Was wondering if knew any place else that sold something like this. Thanks
  #2
Old 09-27-2010, 06:40 PM
WR0220's Avatar
Senior Member
WR0220 is on a distinguished road
Default
The least expensive method I know of is to use a piece of plexiglass. Cut it to fit your window, drill your holes and mount double female bulkhead SO-239 connectors through it. The DIY window passthrough will save you quite a few $$$ compared to the cost of a premade one.
  #3
Old 09-27-2010, 07:10 PM
Default
I've thought of something like that. Or to make the holes big enough to pass my coax through, then use a rubber seal ,and little cocking glue to seal out elements
  #4
Old 09-27-2010, 08:30 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
http://forums.qrz.com/showthread.php?t=212358
  #5
Old 09-27-2010, 10:16 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Those coax "pass through" connectors are called 'bulkhead' connectors, and come in several lengths. Pick the one that would work best for your application.
Got double windows? Make a thingy like a 'T', the top bar wide enough to close both windows on. The vertical part tall enough to allow those bulkhead connectors adequate clearance. Something like a couple of 1 x 4's ought'a work in most cases. Make it as simple/fancy as you like.
  #6
Old 09-27-2010, 11:41 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Ive looked at those MFJ window plates aswell and they are pretty nice they have a ground lug and they even have a passthrough connection for my towers antenna rotor plug
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #7
Old 09-27-2010, 11:42 PM
radiodawg259 is on a distinguished road
If you are not going to run real big power you can use a jumper by Jetstream it is only good for 100 watts,or less.The part # JT1010J2,at randl.com the price is right too 12.95 + the shipping and tax...They also have one at HRO but i have to find the part # for it ,but it was about 60.00 if i rember right..
  #8
Old 09-27-2010, 11:45 PM
TonyV225's Avatar
Default
Ive actually seen those little flat extensions aswell.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
antenna flat wire by the window Johnny Amateur Radio Antennas 11 09-29-2010 08:19 AM
New Low Pass Filter FredInFl CB Radio Gear SwapShop 4 08-24-2010 11:07 AM
DX window 75m reminder for Generals SR385 HF Bands and HF Rigs 28 03-03-2009 06:41 AM
Low Pass Filter Article Master Chief Meters, Mics & Other Accessories 1 04-15-2007 04:42 PM
Zetagi low pass filter problems Spirittalk Meters, Mics & Other Accessories 1 03-12-2007 04:38 AM
Powered by vBulletin®
