Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Installation & Station Setup
Amateur Callsign Lookup
Enter Callsign:
Great Mic Sound for your CB or Export Radio-part 4
Like Tree1Likes
Reply
  #9
Old 12-14-2010, 02:57 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Are you using a linear amp?
Seems that it might be stray RF that is getting into some of your cables. I'm not sure that your wiriing is correct; but I think it is. I'm pretty sure you cannot get talkback in your radio by manipulating the mic wires. I would make my own 1/4 inch jack cables out of high quality cables that are RF approved...
If you have any ferrite clip-on beads, I would put them on the poorer cables and see if it doesn't change things. This may be an indicator of an RF leakage problem. A linear amp will only compound this condition - IMO.
Maybe someone else may know about this talkback dilemma.
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #10
Old 12-14-2010, 08:15 PM
Malcontent297's Avatar
Junior Member
Malcontent297 is on a distinguished road
Default
I get the talkback with or without the linear, even on my friend’s mic tester.
I think it must be something I have wired wrong. I really don’t think it has anything to do with stray RF since it does it on a mic tester where there is no RF. Maybe it’s time to take this to a good radio tech for review. I certainly don’t have the expertise to sort this out.
Malcontent
  #11
Old 12-14-2010, 08:58 PM
359's Avatar
359 359 is offline
Senior Member
359 is on a distinguished road
Default
Quote:
Originally Posted by Robb View Post
This will be needed to use a pre-made footswitch or handswitch from Heil or MFJ.
This is incidental and surely well know, but you can make a PTT out of just about anything. I made this one with a 2 cell AA flashlight, 3 miniature momentaries and some aluminum flashing. It's hooked to a mic and 2 different amps.
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #12
Old 12-14-2010, 09:15 PM
Senior Member
tecnicoloco is on a distinguished road
Default
You might need this too
__________________
Kenwood TS-120S,MC-50 Mic,Yaesu FP-700 PS,Antron 99 W/GP Kit at 20Ft.,4 Elem Sirio Optimized for 27.555 Mhz. RP789 Design at 12 Ft,MFJ 949 Tuner.
  #13
Old 12-29-2010, 01:48 PM
CM-4441's Avatar
CM-4441 is on a distinguished road
Default
Very good info! I will be following your suggestions ASAP. Now...what about the mobiles!
Terry
  #14
Old 01-05-2011, 08:14 PM
jazzsinger's Avatar
Bullshit Buster
jazzsinger is on a distinguished road
Default
Quote:
Terry
Buy an astatic 575-m6 if you can find one,save you hundreds of dollars on all that studio shit and sound every bit as good if not better on almost any radio. it won't flatter the ego as much but will sound just dandy.
__________________
"IT WON'T BE EASIER TO SPREAD YOUR VERSION OF HOW SH*T TICKS"
BOB85-2010
  #15
Old 01-11-2011, 08:05 PM
Transducer Fanatic
CDX-007 is on a distinguished road
Default
I've been recently amazed by the sound quality of the RF Limited 2018 Extreme, when the effects are set to <OFF> of course.
I have a 575 M6 and as good as it is, I like the sound of the 2018 better, probably due to it's condenser element.
hotrod likes this.
  #16
Old 01-11-2011, 10:12 PM
Robb's Avatar
Yup
Wink
Terry
Using pro mics in a mobile can be done. I just wouldn't do it myself. Too much ambient noise being amplified in a car! Better off using a decent mobile mic. The setup I've suggested is best suited for a base station with a quiet background.
I use a RF Limited CR-577 mic in my mobile. Works better than my D-104 Minuteman II. The RF Limited Xtreme 2018 mic is similar too. Verrry clean audio . . .
__________________
"...2 WR-011..."
Reply
Bookmarks
Tags
cb radio, essb audio
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super Wack Pack II secret squirrel Export Radios 148 10-03-2012 05:47 AM
HELP! Service Manual For Cobra 2000GTL?? Robb General CB Services Discussion 15 08-12-2010 02:51 AM
Used CB Radio: How to Buy-Part 5 Robb General CB Services Discussion 3 12-01-2009 06:06 PM
The ARRL Letter Vol. 27, No. 13 April 4, 2008 AudioShockwav FCC & ARRL Activity 0 04-04-2008 03:26 PM
Marine Radio Rules Charger383 Scanning & Shortwave Listening 0 07-07-2002 07:12 PM
Powered by vBulletin®
