Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Installation & Station Setup
Amateur Callsign Lookup
Enter Callsign:
Great Mic Sound for your CB or Export Radio-final
Like Tree1Likes
Reply
  #9
Old 01-30-2012, 05:49 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Quote:
Originally Posted by Whiplash-265 View Post
Quick question for you Robb if i might?
600ohm stock handheld mic (as per stats on the FT-950)
replacement mic Audio-Technica ATM61HE (i see entry level Heil mics are 1000ohm)
ELEMENT Neodymium Dynamic
POLAR PATTERN Hypercardioid
FREQUENCY RESPONSE 50-18,000 Hz
OPEN CIRCUIT SENSITIVITY -51 dB (2.8 mV) re 1V at 1 Pa
IMPEDANCE 600 ohms
OUTPUT CONNECTOR Integral 3-pin XLRM-type
will be using the new Heil CC1-XLR-Y-BAL cable (to eliminate a history of rf)
600=600 so should be no issues correct?
i'll be using the radios internal dsp for now
No problemmo with 600 ohm mic impedance, Marty.
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #10
Old 01-30-2012, 06:19 PM
Senior Member
Whiplash-265 is on a distinguished road
Default
thanks tons Robb!!!! appreciate the sharing of your knowledge and experience
__________________
KP161 = Base : Yaesu FT-950 - Icom ic-718 - 40' Delhi tower - Sirio 2012/Sirio 27-4 ___ Mobile : Magnum 257HP - Wilson 5000
  #11
Old 08-19-2012, 10:59 PM
The Bruce's Avatar
Senior Member
The Bruce is on a distinguished road
Default
Question... and this is assuming you're not bypassing the radio's preamp:
Wouldn't the current coming out of either a preamp or mixer need to be reduced in order to be plugged directly into the radio's microphone connection (mic level vs. line level)?
I'm worried that I might fry a radio.
__________________
Friends help you move. REAL friends help you move bodies.
  #12
Old 08-20-2012, 01:41 AM
Robb's Avatar
Yup
Default
Sure it can fry the radio's mic preamp if you have it too high to start with. Start by turning the mic gain on the radio down all of the way - first. Then, turn up the external preamp to the 10 or 11 o'clock position. Then slowly turn the mic gain on the radio up ever so slightly until you see the radio's meter moving when TXing. Be aware that moving it just a little bit will go a long way and too high may fry the radio's mic preamp.
One can also use an isolation transformer between the external preamp and the radio's mic input. This will also eliminate hum and isolate the signal between the radio and the preamp.
The whole idea is to get clean gain from a clean amp and mic; not to get the sound distorted/over-driven. Otherwise, the whole game is lost.
__________________
"...2 WR-011..."
  #13
Old 08-20-2012, 07:30 AM
The Bruce's Avatar
Senior Member
Default
By isolation transformer, would you be talking about something like W2IHY iBox?
Supposedly, it takes the line-level current and attenuates it back down to mic-level (along with eliminating hum/noise).
Robb likes this.
__________________
Reply
Bookmarks
Tags
cb radio, essb audio
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HELP! Service Manual For Cobra 2000GTL?? Robb General CB Services Discussion 15 08-12-2010 02:51 AM
How to choose your first Ham Radio pt. 2 Moleculo General Ham Radio Discussion 2 12-23-2009 02:25 PM
Super Swing and That Channel 6 Sound ButtFuzz CB Radio Modifications 2 06-10-2009 08:45 PM
The ARRL Letter Vol. 27, No. 16 April 25, 2008 AudioShockwav FCC & ARRL Activity 0 04-25-2008 04:27 PM
Marine Radio Rules Charger383 Scanning & Shortwave Listening 0 07-07-2002 07:12 PM
Powered by vBulletin®
