Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Meters, Mics & Other Accessories
Amateur Callsign Lookup
Enter Callsign:
pryme pmc-200
Reply
  #1
Old 08-23-2011, 01:09 PM
romakdaddy is on a distinguished road
Default pryme pmc-200
i tried wiring it to my RCI 2990 it will change channel up and down and key the radio but even when unkeyed it will modulate through the speaker.i notice as long as the mic is powered on the vu meter on the mic will swing as you talk even when unkeyed is this normal behavior for this mic? ive searched the web up and down and found very little info on this mic.
  #2
Old 08-23-2011, 05:52 PM
Moleculo has disabled reputation
Default
Sounds to me like it's wired wrong, or maybe it's wired correctly but you have a little strand of mic wire shorting some pins. Check the mic pins very carefully.
  #3
Old 08-25-2011, 04:36 PM
Senior Member
Slim is on a distinguished road
Default
That mic will show mod even NOT keyed as long as it's turned on! Sorry I cant help with the mod thru the speaker problem tho. Good luck. Great mics 8-)
  #4
Old 08-25-2011, 08:47 PM
Senior Member
tecnicoloco is on a distinguished road
Default
Quote:
This microphone is exactly the same as the MFJ-299,you got it wired wrong,I build all the cables with CAT-5 and slip some clamp on ferrites to avoid straight rf from my radios,I wired for 4 pin cobra radios,kenwood,yaesu,ranger,etc...,just be careful and watchout for the power pin in the microphone connector from your radio,could fry the preamp in the radio or the mic.
MFJ-297 MFJ-299 MICROPHONES.
PIN1 MIC GROUND
PIN2 MIC
PIN3 PTT
PIN4 PTT GROUND
PIN5 UP
PIN6 DOWN
PIN7 COMMON UP/DOWN
PIN8 DC VOLTS.
My 2 Pesos
Tecnicoloco
__________________
Kenwood TS-120S,MC-50 Mic,Yaesu FP-700 PS,Antron 99 W/GP Kit at 20Ft.,4 Elem Sirio Optimized for 27.555 Mhz. RP789 Design at 12 Ft,MFJ 949 Tuner.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cobra 200 gtl NO AUDIO fairlaneswede Export Radios 12 05-10-2011 05:50 PM
Apollo 200 & Mattco PMS-1000 HeadHunter Amplifiers 1 05-04-2011 06:27 AM
Cobra 200 longhaireddwb CB Band and CB Radios 3 07-30-2010 07:01 PM
SB 200 makes a great Driver Mr Clean Amplifiers 22 07-31-2009 08:17 AM
Powered by vBulletin®
