inexpensive antenna tuner for 10-12 meters on a sigma 4 ?
what would be a decent AND inexpensive antenna tuner that will allow a sigma 4 to make a decent match for a 2950DX usable frequency range ? power would be about 200 pep .
id also appreciate links to simplified/dummy down info on understanding tuners , how they work and what separates good ones from bad ones ..... if possible .
If you plan on staying below 300W, look for a Dentron Jr. Monitor tuner.I've seen these at hamfests and swapmeets as lows as $20.The construction is 10X better than a comparable MFJ.
When i had my Sigma 4 up had it set for 27.000 and did the full 11 meter band no problem didnt go over 1.5 SWR on either end... didnt do high 28's so couldnt say... what it would do there
and Booty you say you have a REAL Sigma 4 with the 3 arials that go to the hoop?
