Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Meters, Mics & Other Accessories
Amateur Callsign Lookup
Enter Callsign:
D104 questions
Reply
  #1
Old 02-26-2012, 08:59 PM
towerdog's Avatar
one-niner-seven
towerdog is on a distinguished road
Default D104 questions
I never had a D-104. I picked one up along with a bunch of other goodies today, wired it up for my galaxy and it didnt work. I checked and rechecked my wiring, it keys, but just makes bad noises. I think the preamp is bad.
Question is, will the D-104 work without the preamp, without the battery.
And could I bypass the battery and get rid of the preamp?
  #2
Old 02-26-2012, 09:04 PM
towerdog's Avatar
one-niner-seven
Default
In other words is the D104 like a powermic you get at a truck stop, or is it of the type that requires amplification to work at all.
  #3
Old 02-27-2012, 03:23 AM
Senior Member
fnkycoldmedina is on a distinguished road
Default
look to see if it has a switch inside that reads E-R if it does and your hooking it to a modern radio make sure its on E . thats for electronic switched radios .
if your radio is old and uses a relay for switching put that switch on R .
a tug8 stand will have this .
check your battery .sounds like the leaf switches inside the neck could be dirty .
report back
if your hooking that to the sonar or that teaberry it needs to be in the R position .
  #4
Old 02-27-2012, 04:11 PM
towerdog's Avatar
one-niner-seven
Default
the soldering was a hack job and the wiring was so old it turned crispy.
I unsolder ed and cleaned everything up.
I dont think I need a power mic, at least not a power mic like you get at a truck stop.
I also had commercial radios in the past I used on ham that had power mic that took voltage from the radio, I think they were electret mics that had to have high voltage to work.
I'll play around with it more this weekend.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HAM exam questions?? Klondike Mike General Ham Radio Discussion 55 11-29-2011 04:53 PM
special max91 d104 with keyup birdie fnkycoldmedina CB Radio Gear SwapShop 5 08-21-2011 07:36 PM
NCVEC Question Pool Committee Withdraws Four Questions ARRL ARRL Updates 0 05-24-2010 01:20 PM
Need D104 mic wiring 4 pin to Cobra GTL 2000 5 pin chuck97405 General CB Services Discussion 8 05-29-2009 03:52 PM
New poster and newbie to cbs with a few questions Caveman CB Band and CB Radios 9 03-15-2002 04:05 PM
Powered by vBulletin®
