Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > Meters, Mics & Other Accessories
Amateur Callsign Lookup
Enter Callsign:
Sadelta Echo master plus classic
Reply
  #1
Old 11-15-2001, 07:25 PM
redfox911
Guest
Posts: n/a
Default Sadelta Echo master plus classic
Am I the only one with problems pertaining to the location of this mike? I Have to set it in front of the radio or on top of the amp to not squeal (50% of the mod, just a touch of echo) and sometimes I have to ground the stem with my hand. Otherwise it works okay, and it's really old.
Eagle2000! Imax2000/x-force xt40012 modified Mobile:
Very modified uni pc68xl into bluejay 250 with d104m6b and Wilson 2000</p>
Worldwide Radio Forum
  #2
redfox911
Guest
Posts: n/a
  #3
Old 09-05-2009, 08:16 AM
617's Avatar
617 617 is offline
Junior Member
617 is on a distinguished road
Default
BUMP to am old post
I am getting this as well (50% mod on Mic or Radio and it stops)
any help plz..
i am running a new Galaxy DX959 with the Sadella echo master plus
my ant is a new Dipole i get a 1.4 SWR on 27.2050 CH.20
and gos up or down 0.2 from 26.6950~27.9650 is it the high SWR doing this?
my SWR is a new Workman HAPS and my power supply is a Astron RS-20M
my DX959 is pulling 3 AMPS on low RF power and 5 AMPS on high RF power
when i talk on low or high RF power i pull 10 to 11 AMPS
The extra 5 to 6 AMPS is pulled bye the RFX75 I have installed
RF power on low it DK 1 WAT and high 9 WATS set to 1 or 9 its swinging right up to 75+ WATS @ 13.V
will do more when it's over volted to 16v to 17v = 105 to 120+ WATS
i am told bye a local that does not know my 10-20 is 1 house over
with my Dipole aimed his way he told me i have a 3 channel spread 1 over and 1 under from the CH i TX on
so for the ones that say its a splatter box don't use them
well i don't think that it's too bad even with the mod at 50%
he told me it was LOUD AND CLEAR he was impressed and he don't have a base setup and told me the 3 CH splatter will not bother him..
Thanks for any help
617 Central Mass kicking back QRT
  #4
Old 09-14-2009, 05:45 PM
Senior Member
Mr Clean is an unknown quantity at this point
Default
Stick a clam shell ferrite bead on the cord up by the radio. I use the same mic and it works great.
  #5
Old 09-14-2009, 05:56 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
Ive seen those mics do this aswell Ive lucked out but I know of one that went out a window and one that went down some basement stairs and that was without someone carrying it LL!!
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #6
Old 09-14-2009, 08:36 PM
Senior Member
Default
I love mine.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
