The mic is a direct copie of a sadelta mk3 they use a cmos 4011 and the caps that do the timing are in nano farads-spend the time on a better project the gain isnt worth the damage you can cause to the small circuit tracks. if you do try to mod the mic you may find you loose the double beep in most cases-or no beep.
