Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Meters, Mics & Other Accessories
Amateur Callsign Lookup
Enter Callsign:
difference between rg/8u vs. rg/8u type ????
Reply
  #1
Old 11-06-2008, 12:37 AM
BOOTY MONSTER
Guest
Posts: n/a
Default difference between rg/8u vs. rg/8u type ????
was told theres a difference . if so , what is it ?
  #2
Old 11-06-2008, 08:53 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
The designation "RG-8/U" describes a particular type of coaxial cable that was once used extensively by the US military. It had to meet some very stringent quality requirements, and it was the best 50-ohm cable for applications up to 1 KW available for many years.
Now, however, the military uses RG-213/U (same size, same characteristic impedance but improved dielectric, tighter shielding, etc). RG-8 is no longer "MIL-SPEC" cable; ANYONE can make up a bunch of cable and call it "RG-8" with impunity. OR, they can call it "RG-8/U type", or just about anything else.
Buy name-brand coax from a reputable dealer (not a truck stop). Check out RG-213/U.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #3
Old 11-06-2008, 10:38 AM
Senior Member
SR385 is on a distinguished road
Default
In the most generic sense...it means the fat coax vs the skinny stuff. 1/2" wide or whatever it is.
I use 213U for HF and 9913 for VHF/UHF or LMR400 if I can find it locally the latter will work for anything, but they are more expensive due to their lower loss rating.
  #4
Old 11-06-2008, 01:12 PM
Beetle's Avatar
Senior Member
Default
Yes, the outside diameter of this type of coax is pretty standard at 0.405".
Don't forget, though, that RG-11 (75-ohm stuff) and many other varieties of coax are available with that same OD. Be sure of what you're using.
__________________
73 de K7KBN
CWO4 USNR RET.
  #5
Old 11-20-2008, 05:28 AM
hookedon6's Avatar
hookedon6 is on a distinguished road
Default
the skinny coax is rg8x. ( "mini-8). It's commercial-hobbyist cable with no mil spec to guide it, so it varies a lot in construction and quality. But it's supposed to be .242" diameter with a #16 AWG stranded center conductor and a "foam" dielectric. It's usually very flexible.
RG8/U is a very old military specification for 52 Ohm coax. It's .405" in diameter with a #13 AWG center conductor and a solid polyethylene dielectric. As a "mil spec" product, it was discontinued 20 years ago; however as a "commercial" product, anybody can make and sell it and it doesn't have to meet any particular specification. RG8/U was replaced by RG213/U decades ago. There isn't a lot of difference, except RG213/U always has a stranded #13 AWG center conductor, at least 95% outer conductor (braid) coverage, and a Type IIA outer jacket material which is more UV-radiation tolerant than the old RG8/U product which was Type I and could degrade with exposure to the sun.
  #6
Old 11-30-2008, 02:59 PM
jazzsinger's Avatar
Bullshit Buster
jazzsinger is on a distinguished road
Default
why use rg213/u for hf and belden 9913 for vhf/uhf,rg213/u is a better mil spec cable than 9913,9913 is made to the old rg8/u spec which doesn't have noncontaminating vinyl pvc sheath.belden 8267 is belden's rg213/u mil spec equivalent.belden cables are decent quality cables as opposed to the no brand rg8/u and rg8/u type cables.
there is no difference between rg8/u and rg8/u type cables,both are crap copies of rg 213/u mil spec and prey on the buyers lack of knowledge in purchasing them believing they are still mil spec cables,the small word type should ring alarm bells,it tells you its fake.
rg8/u was replaced by rg 213/u mil spec years ago,the main difference being as hookedon6 rightly says rg 213/u mil spec has a type 11a noncontaminating vinyl sheath.
rg8x is just shit.
do yourself a favour if buying rg cables make sure they are proper mil spec made by recognised companies.you only get what you pay for.
  #7
Old 11-30-2008, 05:13 PM
Senior Member
Default
Quote:
Because 9913 is lower loss at higher frequencies.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
