Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > Meters, Mics & Other Accessories
Amateur Callsign Lookup
Enter Callsign:
How can i change voltage??
Reply
  #1
Old 09-17-2009, 04:46 PM
radioman24 is on a distinguished road
Default How can i change voltage??
I have 3 7 volt tweey bird noise toy's and they are all 7 volt toys how can i lower voltage from a 9 volt battery to give them the right voltage? all i have in my city to get parts from is a radio shack so please keep that in mind to,lol
Worldwide Radio Forum
  #2
Old 09-17-2009, 07:09 PM
Senior Member
fnkycoldmedina is on a distinguished road
Default
who told you they are 7volt?they are 9 volt toys ,they are made for d104`s and d104`s are 9 volt.
if you want to vary the voltage just hook a potentiometer inline with the power wire and you can slow it down and speed it up .use an old rf gain knob or something similar.
  #3
Old 09-17-2009, 07:19 PM
MisterFatty's Avatar
Senior Member
MisterFatty is on a distinguished road
Default
Actually your mistaken, DJ Electronics made them for both 7 Volt, and 9 Volt, essentially the same except for value of a couple resistors. They tend to buzz with incorrect voltage, and due to age they could even require less than 7 volts to oscillate properly.
  #4
Old 09-17-2009, 08:13 PM
Default
Yeah i got these from misterfatty they are 7 volts and i wanna lower the voltage from 9 to 7 volts what parts does radio shack sell that i can get to do this???
  #5
Old 09-17-2009, 09:09 PM
Senior Member
Default
I'll see what I have lying around, maybe I can make you something up.......
  #6
Old 09-18-2009, 12:30 AM
Default
okay cool
  #7
Old 09-18-2009, 05:51 AM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
Hmmmmm, somewhere around a 1K resistor ought to drop the voltage enough.
__________________
BC
  #8
Old 09-18-2009, 02:18 PM
Senior Member
HiDef is an unknown quantity at this point
Default
You can't use a pot or dropping resistor and still get decent voltage regulation if there is any current draw.
Use (3) 1N4003 or similar diodes in series. Each will drop about .6 volts from the source and allow good regulation.
  #9
Old 09-18-2009, 03:36 PM
Oldtimer's Avatar
Senior Member
Oldtimer is on a distinguished road
Default
You say they are 7 volts and ya want to drop from 9 volts to 7. Am I missing something here?
__________________
My Toys
Johnson Messenger 250 50th year
Connex 3300
2-Cobra 25 LTD Classics
Realistic 454 CB Fone
President Grant Export
Lafayette 625
Spark0matic
Dosey TC3001-P
KLV 550
Pyramid PS-26 KX
A-99
GOD BLESS
  #10
Old 09-18-2009, 03:53 PM
Senior Member
Default
Quote:
These particular tweeties are intended for a 7 volt supply voltage, much like the older TR-175 powered mics supplied, rather then 9 volts.
Not sure where the question lies....
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Voltage Divider Problem moleculo General Ham Radio Discussion 19 08-18-2009 12:28 PM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
What is a "Buck Boost" KENWOOD570 Amplifiers 20 06-17-2007 03:33 PM
Dec. 15 Question pool changes Sonwatcher General Ham Radio Discussion 0 12-04-2006 02:44 PM
Powered by vBulletin®
