Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > MURS / FRS/GMRS
Amateur Callsign Lookup
Enter Callsign:
Kick Butt GMRS radio's
Reply
  #1
Old 12-06-2011, 02:28 PM
Senior Member
9C1Driver is on a distinguished road
Default Kick Butt GMRS radio's
Midland GXT785VP3 Two Way Radios
Several of us just bought several sets of these when Sparky had them on close out for 20 bucks. WOW, they easily have 3-5x the range of my old Uniden 6 mile radio's. Very cool.
  #2
Old 12-06-2011, 03:24 PM
m42duster's Avatar
Senior Member
m42duster is on a distinguished road
Default
I need to get an GMRS station and mobile running. We have nice local repeater nearby that has great coverage. It's pretty busy also.
__________________
"No bastard ever won a war by dying for his country.
He won it by making the other poor dumb bastard die for his country."
~General George Patton, Jr.
  #3
Old 12-06-2011, 07:08 PM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
Quote:
The Midland GXT785 supports a total of 42 channels - 22 standard FRS/GMRS channels and 20 extra channels. Each standard channel supports 142 privacy codes
What are the "20 extra channels" ?
  #4
Old 12-06-2011, 07:43 PM
towerdog's Avatar
one-niner-seven
towerdog is on a distinguished road
Default
we have similar radios at work.....the extra channels are just repeats of the regular 22 channels with permanently set "privacy codes".
I am skeptical of the claim of 5watts output, you ought to look up the FCC ID on the back of it and look up their paperwork. The ones we got are the same chassis as the GXT785 but only put out 1.5w. I am curious what these will actually do.
I personally do not care for them, they are flimsy, especially the shell, of thin, brittle plastic. The solder joint of antenna on these breaks real easy too, and a similar issue is the plastic shell of the antenna (hard non flexible plastic), just falls off. Also next to impossible to tape to a shoulder strap because of where the buttons are located, but I doubt any manufacture thinks of this, just some happen to put the buttons where you can tape it better.
On a good note, their audio is good as motorola, the NiMH battery packs are sufficient, i think 1100mAh compared to 300 or whatever the motorolas are, and they take a common microphone/speaker plug like most professional and ham radios.
I like the motorolas better, about 1.25w, one less battery than the midlands, smaller in size, hold up alot better, will display the "privacy code" someone else is using when its scanning the channels, and just feels good in the hand.
And I use these more than anyone, I also talked to another crew 35 miles away from top of a tower up on a mountain, so it is theoretically possible to get advert range. Typically on the ground level more like 2 miles, much less in rugged terrain, sometimes less than 1/4 mile.
It is what it is, a cheap blister pack radio, but for $20 you got a steal on them.
  #5
Old 01-18-2012, 06:51 PM
Junior Member
x2502 is on a distinguished road
I got a pair of the GXT795vp4 radios last month. It's true that they're cheap and probably fragile, too. But the clarity and range on these little things is surprising. To me, anyway. In a rural area, I was able to talk clearly at a little over 3 miles. In town, they worked well up to a distance of a little more than one mile.
  #6
Old 01-18-2012, 10:13 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
All of these GMRS hand held radios are VHF and 'line-of-sight'. They all have a typical rubber-duck antenna which will further limit their range. They are subject to the same limitations of any HT of the same power output, and that's very limited by the nature of them. The 'possible' range is almost never going to be the 'typical' range. If you consistently get anything near a mile in any sort of built up area, you are doing very good. I certainly wouldn't expect that though, and expecting to get anything like the typical quoted range is really believing in the tooth fairy.
If this sort of radio suits your purpose, then great.
  #7
Old 01-19-2012, 04:57 AM
IMD262's Avatar
Senior Member
Default
GMRS/FRS is on UHF.
  #8
Old 01-19-2012, 05:44 AM
Default
... give me a minute or two and I'll think of a good excuse for that typo...
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Super Wack Pack II secret squirrel Export Radios 148 10-03-2012 05:47 AM
Used CB Radio: How to Buy-Part 2 Robb General CB Services Discussion 9 03-29-2012 01:55 PM
GMRS or MURS? ak rover MURS / FRS/GMRS 20 01-26-2012 02:15 PM
GMRS NEEDS MORE PIRATES towerdog MURS / FRS/GMRS 0 11-22-2009 06:19 PM
Converted 10 Meter Radios! Dwall174 CB Band and CB Radios 11 11-21-2006 05:53 PM
Powered by vBulletin®
