Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > MURS / FRS/GMRS
Amateur Callsign Lookup
Enter Callsign:
tower mounted FRS radio, would this be legal?
Like Tree2Likes
Reply
  #17
Old 03-03-2012, 10:06 AM
Junior Member
JoeHam41 is on a distinguished road
Default FRS Rooftop OK
Tower or rooftop mount of the entire FRS radio is perfectly legal if the only modification is to extend the cable for a headset. You won't have control of volume, channel, etc. Remoting the power would be OK if you don't modify the radio.
Radio Shack sold a rooftop unit, 21-1850, that had the entire radio in a magnetic antenna base and a remote speaker mic with all the controls.
Adding reflectors or parasitic elements is not allowed. Taking advantage of the tower or other existing structures to direct the signal is OK.
  #18
Old 03-03-2012, 07:16 PM
unit_399's Avatar
EL CAPO
unit_399 is on a distinguished road
Default
Quote:
Originally Posted by JoeHam41 View Post
Radio Shack sold a rooftop unit, 21-1850, that had the entire radio in a magnetic antenna base and a remote speaker mic with all the controls. Adding reflectors or parasitic elements is not allowed.
You can do anything you want to improve the performance of an FRS rig, as long as you don't modify the radio. This includes mounting the radio in front of but not physically attached to a dish or reflector, or the use of a better quality external mic. The power output can usually be bumped up a little by using a slightly higher voltage external supply.
I think that the problem of remote mounting (say, on a tower) is that you need a unit with VOX capability and readjusting VOX sensitivity to compensate for ambient noise changes might be a hassle. 73s.
- 399
  #19
Old 03-04-2012, 12:23 AM
KingCobra_CDX882 is on a distinguished road
Default
GMRS being licensed would enable you to do as you asked..
If then licensed for GMRS then you could use the feed for theFRS frequencies ( i highly doubt FCC would conplain with a GMRS license )
However Not having GMRS license then technically it is Not legal or allowed ( you likely would get away with it as well if you had a Ham license..even though it is still not legal to the letter of the law )
If you are to speak solely of FRS Frequencies and the Absolute Legal use of those FRS channels... In that case... No External Antenna or Mic is allowed..
However with GMRS & or Ham license it is Very Un likely FCC or anyone else would conplain or even know unless you used Crazy power
I use MURS as well as GMRS-FRS through my ham gear while using my roof mounted TriBand antenna ( and if to look at the letter of the law..then it is not legal on FRS or GMRS )
  #20
Old 03-04-2012, 12:40 PM
Senior Member
9C1Driver is on a distinguished road
Default
Years ago Rat Shack made a FRS radio that had a mag mount for the car and maybe 8 feet of coax. I have one out back but can't remember the model number. It only functions with the mag mount because the transmitter is in the base of the mount.
The wire from the radio to mount is like 8 strand. We looked into adding say 20 feet of wire to mount it on the roof of a house. The problem is the wire was expensive and the radio's were low powered. We firgured whatever you gained by getting the antenna up would be lost in line loss power.
I really wish these GMRS radio's had a removable antenna so you could add a 36" mobile mag mount. That would really increase the range but I guess that's the last thing the FCC wants is for us to have greater range.
  #21
Old 03-04-2012, 12:43 PM
pro151's Avatar
Just a friendly CB guy.
pro151 is on a distinguished road
Default
Open that bad boy up and adapt a BNC connector to the antenna connection. I am going to have to bust one of mine open myself and see if it can be done.
__________________
MASTER TROLL
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
  #22
Old 02-04-2013, 04:23 PM
Junior Member
bugmenot is on a distinguished road
Default
I'm not aware of any legal FRS radio that takes external speaker/mic. So, I'm not sure how you propose to push the PTT. I guess you can extend the length of the headset cord, and use VOX, but then you have to keep quiet when you are not transmitting.
Another idea: Is it illegal to put two FRS radios with VOX next to each other, and make them work as a repeater? If that's legal, would it be illegal to tape these two radios and mount it on a tower?
  #23
Old 02-04-2013, 07:13 PM
towerdog's Avatar
one-niner-seven
towerdog is on a distinguished road
Default
umm, every radio i ever saw had a mic and speaker jack, even one i got from like 1990 something radio shack had a kenwood standard speaker/mic plug
  #24
Old 02-05-2013, 07:52 AM
midnight special is on a distinguished road
Default
one fellow here where i live has his frs set up on 50 ft tower with a power cube and a simplex repeater set up he had got from radio shack years ago. it works ok to about 3 miles from his house. he has to climb tower every once and while to check on weather proofing but he seems not to mind about it. he is stuck with using one channel. he didnt like the 1/2 mile and less range he first had with frs sets, but seems happy now. the town i am in is small so coverage is about all over town. and techniccally it all legal. i see the simplex repeaters on ebay every once and a while and ussually sell for more than they were new. wished i had bought a bunch of them. 73s midnight special
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Selecting A Shortwave Radio Charger383 Scanning & Shortwave Listening 2 03-02-2013 11:13 AM
Magnum OmegaForce S-45 HP Review Robb Export Radios 205 03-05-2012 11:44 AM
COBRA 148 GTL Review Robb CB Band and CB Radios 40 11-24-2011 07:39 PM
The ARRL Letter Vol. 27, No. 7 February 22, 2008 AudioShockwav FCC & ARRL Activity 0 02-22-2008 05:59 PM
Marine Radio Rules Charger383 Scanning & Shortwave Listening 0 07-07-2002 07:12 PM
Powered by vBulletin®
