Yep, there is also a
UHF "
CB", it is called FRS, ,short for Family Radio Service. Small
FM Radios, most handhelds, that are limited on power and antenna construction that is good for about 1.5 miles on flat terrain. If you have the advantage of elevation(up on a hill top) this range can be much more, these radios work line of sight real well. They work in the 462/467 Mhz range:
Channel 1: 462.5625mhz
Channel 2: 462.5875mhz
Channel 3: 462.6125mhz
Channel 4: 462.6375mhz
Channel 5: 462.6625mhz
Channel 6: 462.6875mhz
Channel 7: 462.7125mhz
Channel 8: 467.5625mhz
Channel 9: 467.5875mhz
Channel 10: 467.6125mhz
Channel 11: 467.6375mhz
Channel 12: 467.6625mhz
Channel 13: 467.6875mhz
Channel 14: 467.7125mhz
more info can be found here:
FRS info
And The GMRS band is also sharing some channels( the two services overlap in frequency range) with the FRS radios, alto the FRS radios are limited by lower power output and not as much
FM deviation(less audio power) than the GMRS Radios. GMRS requires a lic, FRS doesn't, but it is ok(per the
FCC) for GMRS and FRS users to communicate with each other.
Neat little radios for short range use, like keeping track of a family group at a theme park, or similar uses.
CDX 339
RadioActive
</p>
