hey there..
i think more people should use MURS..
it is often over looked and yet being so close to 2 meters with nearly identical operating as 2 meters..
Myself i use a Comet GP-9
this is a high gain colinear antenna of 10 dbi for 2 meters
although this is a dual band antenna for 2 meters and 70cm band (is slightly higher db gain for 70 cm band..about 13.6 dbi)
i can tell you it works great on murs..
with 50 watts i have spoken 130 miles
but then the antenna is on 20
ft of mast while on top of my 3 story building (with guy wires..lol) so it is 52 or 54
ft high at its base..and the antenna itself is 18
ft tall..
http://www.cometantenna.com/products...ID=5&childID=4
if i ever replace this antenna it will be it will be with another dual banded antenna of a high gain colinear antenna being 24
ft tall with a gain by Dimond like this
http://www.rfparts.com/diamond/x700hna.html
well good luck
Later
you might simply want a mono band antenna that is specificly tunable for the frequency you want...so try this maybe
CA-F22GF
http://www.cometantenna.com/products...ID=5&childID=3
later
