WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > MURS / FRS
Notices
MURS / FRS
Reply
  #1 (permalink)
Old 03-07-2008, 06:51 PM
Senior Member
doctor is on a distinguished road
Default HTX 212 EXTENSION
Anyone know where the extension of transmit page is for the above radio on the web, I had it and misplaced it.
Thanks
DOCTOR/795
__________________
WAVING A HAND FROM CORNFIELDS OF INDIANA..HAVE A GREAT DAY
CDX 795/CEF795
QSL11.COM
Member...REACT INTERNATIONAL
  #2 (permalink)
Old 03-07-2008, 07:47 PM
AudioShockwav's Avatar
Senior Member
AudioShockwav is on a distinguished road
Default
I remember reading something about that radio, turning the power on while pressing and holding the F, and DTMF keys should "unlock" the radio.
If you Hold down the F and the T-SQL and power the radio on it will master reset back to factory settings, and clear the memorys.
I will look for that page again.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/javagif/gifs_thumb/20080120_1300_eit_171.gif
NASA/SOHO
  #3 (permalink)
Old 03-08-2008, 08:05 AM
Senior Member
Default
If you find anything else , would appreciate it
tnx
doctor/795
__________________
CDX 795/CEF795
QSL11.COM
  #4 (permalink)
Old 03-08-2008, 05:35 PM
Senior Member
IMD262 is on a distinguished road
Default
Don't quote me, but I don't think the 212 can be opened.There is a mod that will open the TX on the HTX 242 though.
  #5 (permalink)
Old 03-08-2008, 06:30 PM
Senior Member
Default
I know they are about the same, but I cant find the mod for the htx 242 , any suggestions
doctor/795
__________________
CDX 795/CEF795
QSL11.COM
  #6 (permalink)
Old 03-08-2008, 10:00 PM
Senior Member
Default
This is what I have found,I don't know if it will work on the 242 and almost positive it will not work on the 212:
Modification for a Radio Shack HTX-242
« Thread started on: Aug 4th, 2002, 3:25pm »
Posted by Jeff Parrish (KB9GXK) on September 11, 1998
Special NOTICE: This is for the HAMS who say radio shack radio's are "can't be
modified, because the FCC was real strict with Radio Shack", or buy a real radio so
that you can modify it. That is a bunch of bull.
Mod: Expands TX from 143-149mhz to 136-174mhz
Tools Required: Phillips Screwdriver, Mini screwdriver, Soldering Iron (Fine tip) ,
NeedleNose Pliers
Process:
1.Remove Screws on bottom and top 2.
2.Take the Bottom and Top off the Radio.
3.Unplug Speaker from top of the radio and remove the dials from the face
plate.
4.Unscrew the screws on the top and bottom of the face plate.
5.CAREFULLY: remove the face plate from the radio.
6.Remove the bolts and washers (little rings) from the dials (countersunk into the
dials).
7.CAREFULLY: remove the LCD and plastic around it by pulling gentle and
wiggling it a little being careful not to bend the LCD pins.
8.Remove the screws holding down the PCB from the cases.
9.CAREFULLY: (Plug in type PCB) remove the PCB from the radio and place
the VFO tuning dial face down and to your left.
10.There will be two blue jumper mounts on the PCB. Remove the 1 closest to
the 2 black raised chips that are closest to the VFO tuning dial (this jumper
should be near the middle of the board) The other jumper makes the
transmitter do 143-144 (military) and it is near the side.
11.Put all the parts back together and blamo you have 136-174mhz RX/TX
Notes: If you do it right you won't even loose your memories. This mod took me
about 30 minutes to complete and my radio is working fine. However I'm sure this
voids the warranty and the service contracts so you may not want to do it for that
reason alone. I checked the radio out (with a frequency counter) on several
frequencies and it is performing well. This mod requires a little skill but most people
that are hams could do this mod. This mod was given to me by a fellow North
Carolinian KC4VYY , and I just put it in a simpler form.
I wanted to thank him.
  #7 (permalink)
Old 03-08-2008, 10:04 PM
Senior Member
Default
Mod with pics:
http://www.radiomods.co.nz/radioshackhtx242.html
  #8 (permalink)
Old 03-08-2008, 10:27 PM
Senior Member
Sonwatcher is on a distinguished road
Default
Jeff, you may be referring to the 242
Quote:
Question: How do I expand the radio for use with CAP/MARS? Answer: Hold down F and DTMF and turn the radio on.
http://support.radioshack.com/suppor...oc67/67164.htm
__________________
  #9 (permalink)
Old 03-09-2008, 08:08 AM
Senior Member
Default
Thanks guys, will look into it
DOCTOR/795
__________________
CDX 795/CEF795
QSL11.COM
  #10 (permalink)
Old 03-09-2008, 09:23 AM
Senior Member
Default
Could be, I read it somewere, and have searched and could not find the same page.
__________________
Radio-active
NASA/SOHO
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
