The
FT-2800M is a great choice. I can be had for as little as $120.
With the mars mod, it'll do murs without any programming software.
Most two meter antennas should cover 151MHz without trouble, but for 154 i think you would need to trim the whip a tad.
If for some reason you also wanted FRS (on
UHF), there is the
FT-7800R.
