Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > MURS / FRS
Amateur Callsign Lookup
Enter Callsign:
murs mobile
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 12-21-2008, 08:02 AM
Senior Member
doctor is on a distinguished road
Default murs mobile
Anyone ever experience MURS mobile in other cities or areas and is there any activity????
DOCTOR/795
__________________
WAVING A HAND FROM CORNFIELDS OF INDIANA..HAVE A GREAT DAY
CDX 795/CEF795
MURS ...151.94..VOICE OF THE CORNFIELD..795
Member...REACT INTERNATIONAL
CQ100/HAMSPHERE
Worldwide Radio Forum
  #2
Old 12-21-2008, 08:29 AM
Senior Member
park is an unknown quantity at this point
Default
My wife and I use ch. 1 (151.820). We are located in the Austin / San Antonio area and to my amazement hardly hear a thing! I also drove to NE, MO, KY and back to TX earlier this year and heard very little. Didn’t hear much on 146.52 ether.
__________________
Everyone drives like crap but me.
  #3
Old 12-21-2008, 09:14 AM
Wire Weasel's Avatar
Honkus Maximus
Wire Weasel is an unknown quantity at this point
Default
Most MURS use seems to so far be with the short range handhelds. But what the hey...WE like our big radios and extra power....so if you can swing the gear, why not use a full power mobile both mobile and as a base. All the ham 2 meters mobiles mod out to cover MURS. So there ya go, a 50 watt radio. I have a mobile for 2 meters/MURS/Business Bands in the truck and even more capability at the house with a rig that does 100 watts on VHF.
For a most used itinerant frequency, 151.625 is still the most used. Again the ham 2 meter rigs will shine here.
The only problem remaining for ham/dual use, is having an antenna system that will cover both ranges with a good SWR. A tuned-for-2 meter antenna will be seriously out of tune for even the 151mhz channels. Either need some sort of screwdriver arrangement, a really good VHF antenna tuner, or best would probably be two separate antennas.
Good luck and have fun with radios!! That is an order! Carry on.
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
  #4
Old 12-21-2008, 10:03 AM
Senior Member
moleculo has disabled reputation
Default
Lots of MURS activity around Los Angeles....
  #5
Old 12-21-2008, 12:58 PM
Senior Member
Default
Try the MFJ-1728B, it can be used for 2 meters and MURS at the same time with good SWR.
What is the 151.625 freq?
__________________
  #6
Old 12-21-2008, 01:06 PM
Senior Member
Default MURS
I tried simplex from here to Florida, it really worked<1 contact>, so installed a cb again in the car..lots of contacts, it wasn't a dead band again from here to Florida..
DOCTOR/795
__________________
CDX 795/CEF795
CQ100/HAMSPHERE
  #7
Old 12-21-2008, 04:10 PM
Honkus Maximus
Default
Hi Park,
151.625 is Channel #1 itinerant business band VHF channel
Been around forever. Heavily used by construction, land surveyors, hotels ect...
__________________
  #8
Old 01-04-2009, 02:57 PM
Junior Member
Putt is on a distinguished road
Default
Yup, there ya go, uses excessive power.. screw it up just like the 27 Mhz CB band... You use ham gear for MURS?? Not type accepted is it?? Just about as legal as using Ham gear on the business bands...
Putt...
  #9
Old 01-04-2009, 03:00 PM
Junior Member
Default
Not really...
There are several antennas that will cover from 146 to 152 Mhz out there with less than a 2 to 1 VSWR.. Wilson makes a mag mount mobile that will do it....
Putt...
  #10
Old 01-04-2009, 05:03 PM
Senior Member
Default mobile whip
I took a 2 meter 45 inch whip and cut it to 17 inches for 151.94, works great, also found out firestick makes MURS antennas around 9 dollars to 12 each, and you can order directly from the factory since it is a special order.
DOCTOR/795
__________________
CDX 795/CEF795
CQ100/HAMSPHERE
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/murs-frs/31551-murs-mobile.html
Posted By For Type Date Hits
murs mobile - WorldWide Radio Forum This thread Refback 12-21-2008 08:41 AM 1
Powered by vBulletin®
