Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > MURS / FRS
Amateur Callsign Lookup
Enter Callsign:
Fun Trick -- Crossband Repeat!
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 03-21-2009, 08:45 AM
scantheband is on a distinguished road
Lightbulb Fun Trick -- Crossband Repeat!
I used to have fun on MURS using my Kenwood TM-V7A as a crossband repeater. When I would be away from the rig, I would set the 'V7A to crossband repeat my Yaesu FT-50RD HT's FRS signals over to MURS, and incoming MURS traffic would then be repeated back to the HT on FRS.
That way, my little HT would have some pretty amazing "range" (30+ miles) on MURS. I could be out in the neighborhood, the yard, anywhere in the house, etc., and still be able to work at distances much farther on MURS than my HT alone would have offered.
Has anyone else tried this?
__________________
CB'er since the sixties;
Ham since the seventies;
Plum Loco since birth.
Worldwide Radio Forum
  #2
Old 03-21-2009, 09:58 AM
Senior Member
scout943 is on a distinguished road
Default Trick
I have always wanted to try that with some cheap gmrs/frs radios !
  #3
Old 03-21-2009, 02:32 PM
Cheech's Avatar
Senior Member
Cheech is on a distinguished road
Default
I have a couple motorolas set up this way. I stopped using frs and gmrs on the uhf side though as there is just to much traffic. Swithed over to uhf dot freaqs.
__________________
CDX 825
Cobra 200GTL DX
Cobra 148GTL
Cobra 146GTL
Cobra 25
HR 2510
Texas Star 350
Jumbo 400
Yaesu FT 2800M
Motorola M1225
Hustler G7 150-1
Hustler G-2537 .64
Iota DLS-45/Optima D34
  #4
Old 03-21-2009, 03:37 PM
Senior Member
doctor is on a distinguished road
Default dot frequencies
What is dot frequencies...frequencies???
GMRS is dead here, and FRS me and 2 friends....
DOCTOR/795
__________________
WAVING A HAND FROM CORNFIELDS OF INDIANA..HAVE A GREAT DAY
CDX 795/CEF795
MURS ...151.94..VOICE OF THE CORNFIELD..795
Member...REACT INTERNATIONAL
CQ100/HAMSPHERE
  #5
Old 03-21-2009, 04:04 PM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default
UHF "dot" frequencies are itinerant UHF business band frequencies.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #6
Old 03-21-2009, 09:31 PM
dudmuck's Avatar
Senior Member
dudmuck is an unknown quantity at this point
Default
The killer setup is a repeater that outputs onto a CB channel.
Imagine a repeater inputing on FRS or MURS (with a PL tone of course), and then outputing on a CB channel. It would drive crazy the other CBers not on the system. But for such a repeater to be useful, it would need to be located on a hilltop or building-top.
Such a system did exist here in Los Angeles in the 80's. It was a dual-hilltop repeater.
It would input on a hill 50 miles away, in big bear, and then link on 49MHz, and then output from atop palos verdes hill. It was great fun since CBers would drive to palos verdes to jam it out, not knowing that it was linking from another hill via 49MHz.
But such things were not meant to last, and the FCC eventually caught up with it.
__________________
"Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist
  #7
Old 03-22-2009, 11:16 AM
Happy_Hamer's Avatar
...{}/_\{}...
Happy_Hamer is on a distinguished road
Default
Well, I have a Kenwood TS-2000
Put that on Cross Band and I can do just that.
Set the sub side of the radio on 151.940 and the main, well anywhere on HF
I have done it into a set of dummy loads but using antennas,,,,
NOW, that is illegal so I would NEVER do that
__________________
That's how I roll!!
  #8
Old 05-21-2009, 04:40 PM
TheTeZ's Avatar
TheTeZ is on a distinguished road
Default
so... how is this set up? What do you need?
  #9
Old 05-21-2009, 05:54 PM
Senior Member
moleculo has disabled reputation
Default
a 2m/440 radio that can be modified out of band to talk on murs & frs/gmrs. Just don't do this in the ham bands if you don't have the ticket. The TS2000 that Hamer mentioned works, the Yaesu 8800, Icom 2720, a few others...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/murs-frs/33098-fun-trick-crossband-repeat.html
Posted By For Type Date Hits
Поиск.Ru - Crossband Couple This thread Refback 06-24-2009 01:19 AM 1
Powered by vBulletin®
