Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Product Reviews
Amateur Callsign Lookup
Enter Callsign:
Kenwood TM-D710A Video Review
Reply
  #1
Old 02-13-2012, 09:51 AM
Se7en's Avatar
Se7en is on a distinguished road
Default Kenwood TM-D710A Video Review
here is two video reviews i did on the radio i didn't cover APRS because i haven't gotten the cable yet to plug in my nuvi 1450LTM.
review 1:
review 2:
__________________
Many people are very Insecure. They need to surround themselves with exclusive Friends to Validate their own self worth.
  #2
Old 02-13-2012, 01:09 PM
KE5MC's Avatar
Senior Member
KE5MC is on a distinguished road
Default
FYI
You don't need the GPS connected and running, you only need a valid location so the incoming packets will show a meaningful bearing and distance. Load MY POSITION and then you can proceed with the next youtube.
Copy and paste from the PDF manual.
When the GPS receiver is not connected to the TM-D710(fixed station), set the GPS receiver Menu No.602(GPSPORT–INPUT) to [OFF] (default value). If you do not connect the GPS receiver when you set up [GPS], your station position location will not be correct, and the distance and direction of other stations will not be displayed. Therefore, you should set your position data using Menu No. 605 (MY POSITION).
__________________
The road goes on forever and the party never ends...
  #3
Old 02-13-2012, 04:13 PM
Se7en's Avatar
Default
Quote:
Originally Posted by KE5MC View Post
FYI
That sorta makes sense...... I did what u posted what's supposed to happen ?
Sent from Outerspace, on the DarkSide of X.
__________________
  #4
Old 02-13-2012, 04:50 PM
KE5MC's Avatar
Senior Member
Default
Sheepish grin!
Not sure. Always relied on GPS input. I know that beacon does not work until the gps symbol on the display started blinking. During that time of non-blinking time I think the heard packets will not be displayed.
If aprs packets are heard and displayed do they have realistic distance displayed? Usually you don't see anything beyond about 40 miles unless someone has setup their radio for more than 2 hops. WIDE1-1 and WIDE2-1 is the typical recommended setup.
You could try changing the LAT/LONG and see if you get different results from stations you have already heard and see if you move you location around on "http://aprs.fi/info/a/KE5MC-9". Change my callsign for yours.
Mike
PS Don't expect aprs.fi to quickly show your position. It goes into the internet and floats around for awhile until processed and displayed. I can't say how long the updates take to be displayed.
__________________
  #5
Old 02-13-2012, 05:10 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
If you enter your position (fixed), set the frequency to 144.390, and turn on the TNC to the first (click) position, you will see the stations sending position reports. There are more than one way to display that information, select the one you are comfortable with. After you've entered your position, the radio will then give you the direction and distance from you of the stations heard.
That can all be done from the panel buttons or by means of the free Kenwood program. Get the program (MCP-2A), it's much simpler. Either get or make a programming cable while you're at it.
  #6
Old 02-13-2012, 07:28 PM
Se7en's Avatar
Default
i was going to buy the cable needed from garmin to make my NUVI 1450LTM work with the kenwood but it seems all that aprs is sorta hard to use lol i tried doing the settings as posted first and it didn't do anything? i was NOT on 144.390 so maybe thats why it didnt do anything. i used my gps to get my long lat and input let me go try this 144.390 see what pops up? i dont plan on getting the programming cable don't seem to need it been doing okay so far getting it programmed properly with alpha tags and all.
__________________
  #7
Old 02-13-2012, 07:45 PM
Se7en's Avatar
Default
wow cool stuff all this popped up when i turned on TNC and did APRS12
__________________
  #8
Old 02-13-2012, 07:51 PM
Se7en's Avatar
Default
i am reading this about APRS: http://www.ei7ig.org/files/IntroToAPRS.pdf
MODS if all this replies but the review be moved to the proper forum that would be great? if my video review is not sufficient enough it too can be moved. ty
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenwood TH-D72 2m/440 APRS HT Review Moleculo Product Reviews 94 02-14-2012 08:34 AM
W2IHY 8 Band EQ and EQPlus Video Review Moleculo Product Reviews 18 05-13-2011 06:06 AM
ToDay was Nutts fortymobile DX Contacts 0 10-22-2010 07:45 PM
Dx was off the Hook today fortymobile DX Contacts 2 10-22-2010 12:25 AM
RCI-2980 Video Review and Walk-through cbradiomagazine.com General CB Services Discussion 1 11-05-2007 05:13 AM
Powered by vBulletin®
