Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Product Reviews
Amateur Callsign Lookup
Enter Callsign:
Yaesu FTM-350 APRS Review
Like Tree2Likes
Reply
  #33
Old 01-25-2010, 08:27 PM
Moleculo has disabled reputation
Default
Quote:
Originally Posted by KJ4LNZ View Post
Does the serial port in GPS mode output the $GPWPL NMEA string when receiving a beacon from another APRS station?
No it does not. The GPS output mode sends out your own GPS information only. The packet output mode sends out whatever packet information is received by the internal TNC. The location/GPS information from a beaconing station is the same as whatever was included in the APRS message.
  #34
Old 01-26-2010, 09:33 AM
Junior Member
KJ4LNZ is on a distinguished road
Default
Do your outgoing beacons get dumped to the serial port in packet mode or just the incoming packets? If not, then I don't see how you would integrate this radio into a useful map display without having a second GPS to feed your position. At least with an NMEA interface you would be able to have your GPS talk to both the radio and your mapping system.
After a bit more research, it seems like sending the APRS packet is way more useful anyway than just the $GPWPL, but knowing where I am would be nice too.
Bryan.
  #35
Old 01-27-2010, 08:43 AM
Default
Good question, and I didn't try that yet. I'll test that out tonight and report back.
  #36
Old 01-28-2010, 02:15 PM
Junior Member
ki6wbx is on a distinguished road
Default
Does the FT-350 do Voice Alert, i.e., have the option to open up squelch on the APRS channel if PL-100 tone squelch is encountered? The TM-D710 has that option, and lack of Voice Alert is one of the things that disappoints me about my VX-8R.
snakyjake likes this.
  #37
Old 01-28-2010, 08:44 PM
Default
Quote:
Yes it does. I tested it tonight and it works perfect. Thanks for that linked article. I wasn't even aware that others were doing this, so this gives me a new tool in the arsenal! I also tried to find a work around on the VX-8, but it doesn't support setting a CTCSS on the APRS band.
  #38
Old 01-28-2010, 08:56 PM
Default
It does not dump your APRS transmissions to the serial port. However, if your transmission was picked up by a digipeater/igate , you will see it digpeated right back to you, which is then output to the serial port. So in that sense, you still could track yourself using an external program if you're in range of a digipeater.
  #39
Old 02-06-2010, 07:59 AM
Junior Member
NY ESU is on a distinguished road
Default Questions
First off, thanks to all contributors for all the great reviews and information on this radio and the VX-8R.
Just received the FTM-350 last evening and your posts have really made getting it up and running a pleasure.
Since I'm a newbie to ham radio, packet and APRS, I really appreciate all your help.
What is the best side of the radio to run APRS? What are your thoughts on benefits/drawbacks to either side setup? Right now I have it running on the left side, but I know each side has different receive capabilities so your input is appreciated.
Secondly, I'm trying to get the radio to interact with AGW Packet Engine and AGW Tracker. I've had sucess with the VX-8R using the soundcard TNC but can't seem to get the correct setting for the packet com port operation from the 350. Again, any help would be greatly appreciated.
p.s. no lockups so far, though I didn't leave it on all night.
Thanks,
Glenn
N4ESU
  #40
Old 02-06-2010, 08:34 AM
Skysho is on a distinguished road
Default
Only thing I'd suggest you check the setting E16 Data Band Select. The default is 1:APRS Sub Band and I switched to R-Band Fix (in your case L-Band Fix). In the default setting, if you have APRS set as the main band, it will transmit on the sub band on whatever freq you have it set on. In my case it was the local repeater so I became a popular individual and not in a good way. I have no idea why that is setup that way unless its to insure you don't miss receiving a beacon while transmitting yours. So in a true emergency situation, that would be critical. Just my two cents.
Reply
Bookmarks
Tags
aprs, yaesu ftm-350r
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/product-reviews/41539-yaesu-ftm-350-aprs-review.html
Posted By For Type Date Hits
Yaesu FTM-350R - Expedition Portal Forum This thread Refback 02-01-2010 03:49 AM 1
Yaesu FTM-350R - Expedition Portal Forum This thread Refback 01-26-2010 01:25 PM 1
Yaesu FTM-350R - Expedition Portal Forum This thread Refback 01-26-2010 10:46 AM 8
Yaesu Amateur Radio Equipment This thread Refback 01-25-2010 07:00 PM 1
Yaesu FTM-350R - Expedition Portal Forum This thread Refback 01-23-2010 08:04 PM 1
Yaesu FTM-350R - Expedition Portal Forum This thread Refback 01-23-2010 05:10 PM 94
Yaesu FTM-350R - Expedition Portal Forum This thread Refback 01-23-2010 04:45 PM 5
Yaesu FTM-350 APRS Review This thread Refback 01-20-2010 10:57 AM 1
Similar Threads
Yaesu VX-8r Review Moleculo Product Reviews 250 06-22-2013 05:38 AM
Yaesu FTM-350 Review Moleculo Product Reviews 180 07-25-2012 07:29 PM
Yaesu FT-897D Review Moleculo Product Reviews 25 04-20-2012 10:22 AM
Video: How to send an APRS message with the Yaesu VX-8r Moleculo Digital Modes Discussions 6 11-01-2010 02:03 PM
Peek at new Yaesu FTM-350 APRS Mobile rig Moleculo VHF/UHF Bands and VHF/UHF Rigs 5 12-23-2009 11:33 AM
Powered by vBulletin®
