Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Product Reviews
Amateur Callsign Lookup
Enter Callsign:
Elecraft K3 Build Photo Diary
Reply
  #17
Old 08-06-2010, 10:54 AM
Moleculo has disabled reputation
Default
Since I bought the 100 watt Power Amplifier option, we have to install the shield for it. You also have to move the frame stiffener that we used on the top cover install to the chassis for this option.
Here is the bottom of the main RF board. There are a few stand offs that get installed on the bottom where the covers will attach which you can see in the picture.
After that is done, the bottom stand and feet get attached to the front half of the bottom cover.
The Noise Blanker board is installed
Insert the battery
I bought the General RX board option, so now that board is installed.
Attach the front half of the bottom cover and put some adhesive thermal transfer pads over the low power amplifier transistors. These will contact the other part of the bottom cover, making it act as a heat sink.
Now the bottom cover is attached. Note the difference in the screws in the middle that attach to the LPAs
Finally, the 10 watt Elecraft K3 is assembled. If you purchased the 10 watt version, you would just finish the build by putting some plates across the back, but this the 100 watt version so I'll install the fans later.
Now it's time to do the calibration and testing before installing the 100 watt PA.
  #18
Old 08-06-2010, 04:37 PM
Default
Well, I tried to finish the initial build before installing the 100 watt PA section by performing the necessary calibration. I ran into problems. When I try to run the calibration routine, I get an error message that you're not supposed to get. It's displaying ERR VCO 00005.
I tried all of the troubleshooting steps listed for these types of errors, but I couldn't get it to go.
I also have another problem, which is that now the unit will not power completely off. The only way to completely power it off is by pulling the power plug. Here is what it looks like:
What is also weird is that when you plug the power cable back in, the unit starts up automatically. I'm pretty sure it didn't do this before I tried the synthesizer calibration, but I could be mistaken. The manual says to try pulling the boards one at a time to try and locate this problem (which I did), but I couldn't find it. I even pulled the display off and inspected all of those pins but I didn't find anything unusual.
I called Elecraft tech support and left a message and got a call back about 1/2 an hour later. They had me try a couple of things that I had already tried and then told me to send it to them so they could look at it. I hope it's not something I did wrong!
  #19
Old 08-06-2010, 06:25 PM
0x33f is on a distinguished road
Default
Sad to hear man.
  #20
Old 08-06-2010, 07:23 PM
Senior Member
Hutch is on a distinguished road
Default
That really does suck, up until this I was really entertaining the idea of building one of these.
  #21
Old 08-06-2010, 09:14 PM
Default
Quote:
I wouldn't be discouraged because of this minor set back. The build has been very fun and the K3 build design is very well thought out. I'm sure this is some simple thing that I did wrong or just some fluke problem. When I have more info, I'll be sure to update everyone so the same mistake can be avoided.
  #22
Old 08-08-2010, 06:17 PM
Default
I had an opportunity to do some troubleshooting with another K3 owner yesterday...actually someone who was one of the very first run of purchasers: W6NIA. I took my rig over there and we tried swapping his synthesizer board for mine to see if that would solve the problem. It did not. So, there is something wrong somewhere on mine that is not obvious. It's probably something simple like a stray solder splash or something I screwed up, but it's going back to the factory to find out. When I talked to tech support on the phone Friday, they said that they would give me a full report on what they find.
So, while it's a bummer that my rig isn't working right now, the upside is that I can now report out what the tech support process is like. Every Elecraft owner I've ever talked to raves about the support, so it's my turn to find out. If nothing else, it gives me something else to write about
BTW, I did get to play with W6NIA's fully loaded K3, and all I have to say is WOW!! I have never used a rig this good before, and it blew me away. I think I'm going to have a lot to write about in the upcoming review!
  #23
Old 08-09-2010, 05:03 PM
King of NY
linearone is an unknown quantity at this point
Default
Mole,
WOW, Kudos on having the chutzpah to build this rig. I have looked at their stuff for years now and never had the guts to try it. It looked like fun in the ad but I didnt realize that it required NO soldering. I didnt realize it was just an assembly job, a LONG and tedious one. but hey this is fun right! On a serious note you have inspired me and it might make the list for a future project.
I bet their repair dept will be cheaper than yaesu or kenwood or icom. I wouldnt be worried.
It really does look like fun.
Cheers
__________________
Bomb Diggity!
_____________________________________
Quote Bob85: "peoples' personal non factual opinions mean nothing to me period, BS is 10 cents a gallon anywhere you look for it"
  #24
Old 08-09-2010, 08:09 PM
Default
Thanks Linearone.
I can assure you that the assembly process was very fun. It's not really that complicated, as I hope I've shown. I'm not done with it yet because I still have the 100 watt PA to install. There are also a lot of other options that you can purchase to install, as well. I've had a small setback with mine, but it doesn't seem to happen very often. I've spent some time searching the Elecraft listserv (I refuse to call a listserv a "reflector") and found virtually no problems reported from other kit builders. Of course, nothing in manufacturing is perfect, which is why it is important to find out about the customer service experience. If anyone has read any of my other recent product reviews, they will remember that I also had a few minor issues with the Yaesu VX-8r and discovered several serious problems with the Yaesu FTM-350 that were fixed as a result of the reviews by me and other members here.
Keep in mind, that I bought this rig on reputation alone and have only seen it in person at Dayton. I've talked extensively with W6NIA about it, as well and decided to try it out over some other rigs that I could have purchased. After what I saw this weekend when I played with one, I don't think it was a bad decision. After I get this rig going, I'll have plenty of info and demos to show. And if kit building isn't your thing, you can always purchase one built and tested from the factory.
Reply
Bookmarks
Tags
elecraft k3
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HF homebrew tube amp photo build Radio Tech Home Brew 48 06-20-2012 01:43 PM
Just pulled the trigger on a new Elecraft K3 Moleculo HF Bands and HF Rigs 12 08-04-2010 06:41 PM
Build your own cheap VHF & UHF Yagi antennas Moleculo Home Brew 7 07-19-2010 05:22 PM
Coil Loaded Dipole build - photo diary Moleculo Amateur Radio Antennas 44 02-09-2010 06:19 PM
Elecraft 2T-Gen - 2 tone oscillator build / review Moleculo Product Reviews 1 02-09-2009 02:37 AM
Powered by vBulletin®
