Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
Cobra 29 High Power mod with 2sc1969 transistor
Reply
  #41
Old 09-23-2009, 08:06 PM
Junior Member
rockman is on a distinguished road
Default
Its a PDC 550. Nothing fancy, but I know it works checked it against two other radios, a stock, that is doing 4 watts and a modded 25 that is swinging 30 watts.
Worldwide Radio Forum
  #42
Old 09-23-2009, 08:16 PM
MisterFatty's Avatar
Poppin Fresh!
MisterFatty is on a distinguished road
Default
I was just looking at a few Spec sheets for various manufacturers IRF-530, they appear to have a fair range capacitance values listed. Do you happen to know specifically who made the one your using?
  #43
Old 09-23-2009, 08:18 PM
Junior Member
Default
Yes International Rectifier, I beleive is who it is.
  #44
Old 04-28-2010, 11:58 PM
Junior Member
Grey Coyote is on a distinguished road
Default
I thought i was following this thread pretty good, but maybe i missed it. A question was asked about which side of band of D11 would you connect the 1k resistor in step number 6. I would like to know that also.
Thanks.
  #45
Old 05-07-2010, 02:24 PM
Junior Member
Dago 971 is on a distinguished road
Default
Quote:
Originally Posted by moleculo View Post
I was asked by a few people how to do this mod, so I figured I'd just post it up.
Please don't copy and paste this mod to other sites/forums, but feel free to link to it.
Also applies to:
Uniden 78
Cobra 25 & Uniden 76 mod is similar, although you'll need to cross reference against the schematic.
1: change the final to a 2sc1969
2: change the driver to a 2sc2314.
3: change the electrolytic capacitor by the audio IC (C42, 1000uf) to a
3300uf, 16v.
4: Take a turn off the output tuning coil (see tuning coil note below)
5: Remove the AMC potentionmeter (VR4), and put a 1K resistor in it's place.
(only two connections are used on this pot, use those two connections
for the resistor)
6: add a 1K in series with D11.
7: Change R48 to a 33K ohm resistor.
8: Change R55 to a 10K 1 watt resistor.
9: change C37, and C68 to a .2 monolythic (this changes the A.F.
response on TX)
10: Now align the radio, start with the output coil, the the predriver
stage for peak output.
11: Tuning notes: Tune L17 for max with audio. Then, tune L23 for max output with audio, this will upset the radio's frequency. So, after L23 is set, adjust L24 to put the radio back on frequency.
Tuning coil note: If the radio says "made in China" on the back, you must remove 1 turn from the output tuning coil with the slug in it. If it doesn't then you may or may not have to. Count the turns, if it has 4, leave it alone, if it has 5, it's too many and won't tune, remove a turn. You may have to add a 68pf capacitor from the left terminal of the coil to ground, with the solder side of the board up. This method produces better results than just removing the tuning slug.
This mod will consistently produce output between 10-12 watts AVG and 45-50 watts peak. If I can find my video clips of Bird 43P power meter and spec analyzer I took after doing this mod, I'll follow up with those.
This looks very similar to a Dave Made Cobra 29 I was able to peek at under the hood. IS this infact his mod or similar to it? I know the Dave Made Cobra 29's are fantastic Shoot Out Radios...
  #46
Old 06-05-2010, 09:04 AM
ses ses is offline
Junior Member
ses is on a distinguished road
Lightbulb Cobra 89XLR MOD 2sc1969 and 2166 Installation.
HELLO. I WOULD LIKE TO SEE THE PROCEEDURE FOR INSTALLING 1969 AND 2166 IN COBRA 89XLR AND WHAT COMPONENTS TO CHANGE TO GET THE BEST PERFORMANCE. THANK'S IN ADVANCE SCOTT.
  #47
Old 08-13-2010, 11:36 AM
frogman296 is on a distinguished road
Default
where does one buy .2 monolithics? i assume they are 0.2uF, correct??
  #48
Old 08-13-2010, 05:31 PM
dudmuck's Avatar
Senior Member
dudmuck is an unknown quantity at this point
Default
For an in-production equivalent to 2sc1969, you might want to look at the 2ST1480FP
http://www.st.com/stonline/products/.../2st1480fp.pdf
It has similar specifications.
Perhaps transition frequency of 120MHz is adequate for 27MHz operation?
These days, TO-220 is not a good package. Its easier to find stock of bipolar high frequency power transistors in TO-252. Bit the 2ST1480FP is TO-220.
__________________
"Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist
  #49
Old 08-17-2010, 03:58 PM
Default
what about the cb20w or the eleflow transistors??
Reply
Bookmarks
Tags
cobra 29, cobra 29 50 watt, cobra 29 high power, cobra 29 mod
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/radio-radio-related-modifications/31449-cobra-29-high-power-mod-2sc1969-transistor.html
Posted By For Type Date Hits
2sc1969 | VIRGILIO Ricerca | Web This thread Refback 09-02-2009 09:04 AM 2
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1
