Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
Yaesu VX-8r mod - first on the internet!
Reply
LinkBack (28) Thread Tools Display Modes
  3 links from elsewhere to this Post. Click to view. #21
Old 04-06-2009, 09:05 AM
cnd cnd is offline
Junior Member
cnd is on a distinguished road
Default
Quote:
Originally Posted by alaskann7phb View Post
Next question, does this radio transmit AM on aircraft band (122.900) as does the VX-7R?
The VX-7R does NOT transmit AM on air-band - it transmits FM. If you happen to know a mod to make it TX in AM - do please share!!!!
Worldwide Radio Forum
  #22
Old 06-27-2009, 12:10 PM
Supporting Member
ke7vvt is on a distinguished road
Default
RX
Frequency Note
0.5 - 1.8 MHz BC Band. AM Radio
1.8 - 30 MHz Shortwave Band.
30 - 78 MHz 6 Meter Ham
76 - 108 MHz FM Radio
108 - 137 MHz Air Band
137 - 174 MHz 144 MHz Ham. 2 Meter
174 - 222 MHz VHF-TV
222 - 225 MHz 222 MHz Ham
225 - 420 MHz General Band 1
420 - 470 MHz 440 MHz Ham. 70 cm.
470 - 800 MHz UHF-TV
800 - 999 MHz General Band 2 Cellular Blocked
TX
50 - 54 MHz
144 - 148 MHz
222 - 225 MHz USA version only
430 - 440 MHz
TX w/ mod
50 - 54 MHz
144 - 148 MHz
148 - 174 MHz MARS/CAP Mod only
430 - 440 MHz
440 - 470 MHz MARS/CAP Mod only. FRS/GMRS freq range
  #23
Old 07-17-2009, 10:59 PM
Supporting Member
Default
Quote:
Originally Posted by Marc Duncan View Post
Yep! It works.
I grabed the resistor with the tweezers and it crumbled. No hot iron required!
I would say it was designed to be a scrape-away option.
All systems go.
I just did another mod, the first time I melted the plastic in a few places with my soldering iron.
This time I used a xacto knife and gently cut the resistor out. The solder is very soft. The biggest pain of doing this mod is getting that sticky adhesive off.
  #24
Old 07-26-2009, 12:29 PM
Junior Member
Milos is on a distinguished road
Default
Hello everyone. This is my first post and thanks to VX8R unit, i signed up here. Thanks everyone for lots of great info. I am hooked to this new field.
I have one question about mod mentioned here.
Is there any reason to think this mod will negatively affect this radio at all. I read unconfirmed information that it destabilizes Tx power in certain bands, or even reduces power transmission overall. It doesn't sound logical to me, but i figured i should ask here before i perform the mod.
thanks a lot in advance.
best regards
  #25
Old 07-30-2009, 03:05 AM
Junior Member
cheewooi is on a distinguished road
Default
I did the mod on my new VX-8R.
Quote:
power on
SET mode
#21 CWID
CWID (ON)
push "MODE"
turn DIAL to A, push "MODE"
turn DIAL to H, push "MODE"
repeat 6-7 ,to type in "AH029M"
push "SET" to get out set mode
power off
oush HM/RV + MENU power on
turn DIAL to choose MODE ***
push Function/w
power off
pwoer on
After mod band will be: 120-173.995MHz, 220-221.995MHz,400-469.995MHz,300-576MHz
But I notice that if the tx frequency is less than 140.000mhZ, the voice is very very soft. Barely noticeable. I tested my VX-8R with 3 unit of FT-60R at 137.025mHZ, the voice is barely noticeable. But when I tune my VX-8R to 140.000mHZ the voice is loud as FT-60R.
The funniest thing is, my FT-60R can transmit at 137.000mHZ without any modification and the voice is very very clear.
  #26
Old 07-30-2009, 12:53 PM
Senior Member
moleculo has disabled reputation
Default
best regards
I haven't seen any negative effects of the "remove the resistor" mod on mine. The power output within the ham bands is the same as before. The power will drop off the farther you get out of the ham bands, but that's pretty common with all radios.
  #27
Old 08-03-2009, 08:57 PM
Junior Member
Default
thanks for your answer, and great review of this unit molecuo!
cheers
  #28
Old 10-02-2009, 09:37 AM
Junior Member
bigtings is on a distinguished road
Default vx-3e
hello rther all, im wondering how to transmitt on other channels on my vx-3e. there have been mods posted online however i cant seem to folow them... on a vx-3R its pritty simple, just remove the jumper, however on my vx-3e the circuits behind the battery is different..
any suggestions?
Reply
Bookmarks
Tags
vx 8r mods, vx-8r mod, yaesu vx-8r, yaesu vx-8r mod
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/radio-radio-related-modifications/31824-yaesu-vx-8r-mod-first-internet.html
Posted By For Type Date Hits
Yaesu Vx 8r Mod - Your Hot Search | Page 1 This thread Refback 10-24-2009 01:07 AM 2
Amateurfunk Forum - YAESU VX 8 ERWEITERUNG aber wie/was??? This thread Refback 10-04-2009 10:59 AM 140
Amateurfunk Forum - YAESU VX 8 ERWEITERUNG aber wie/was??? This thread Refback 10-04-2009 10:57 AM 3
Vx8r Mod - Your Hot Search | Page 1 This thread Refback 10-02-2009 03:48 PM 3
Yaesu VX 3 mods This thread Refback 09-14-2009 04:02 AM 2
Yaesu vx-8r mods This thread Refback 09-09-2009 09:33 PM 36
Vx-3 mod This thread Refback 07-28-2009 10:02 AM 3
Amateur Radio User This thread Refback 07-17-2009 10:42 AM 2
Yaesu VX-3 mods MARS cap This thread Refback 07-12-2009 03:22 AM 2
Vx-8r modifications This thread Refback 07-09-2009 04:44 PM 23
Yaesu VX-3R mods MARS cap This thread Refback 07-09-2009 01:45 AM 15
Yaesu VX-3R mods Freeband This thread Refback 07-07-2009 09:24 AM 13
YAESU VX-3 mod This thread Refback 07-06-2009 11:41 PM 16
VX8R : Messages : 263-317 of 726 This thread Refback 07-05-2009 03:51 AM 4
Yaesu vx-7r modifications This thread Refback 07-02-2009 03:17 AM 16
YAESU VX-3e modifications This thread Refback 06-14-2009 03:45 PM 1
YAESU VX 3e modifications This thread Refback 06-09-2009 08:16 AM 17
Yaesu VX-3 modifications This thread Refback 06-03-2009 07:07 AM 7
YAESU VX-3R mod This thread Refback 06-02-2009 07:17 AM 11
Out of band TX on the Yaesu VX-8r This thread Refback 05-02-2009 06:17 PM 233
Vx-8r mod This thread Refback 04-21-2009 10:37 AM 81
Vx8r mars mod This thread Refback 03-13-2009 09:23 PM 31
Vx-8r mars-cap mod. This thread Refback 03-07-2009 03:31 PM 88
Vx8r mod This thread Refback 02-25-2009 09:20 PM 43
VX-8R MARS/CAP mod This thread Refback 02-23-2009 10:57 PM 178
VX8R : Messages : 275-304 of 346 This thread Refback 01-15-2009 01:49 PM 6
VX-8r mod | Addictomatic This thread Refback 01-13-2009 10:30 AM 215
Yaesu VX-8r mod - first on the internet! - Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF This thread Refback 01-04-2009 11:12 AM 1
Powered by vBulletin®
