Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Yaesu VX-8r mod - first on the internet!
Reply
LinkBack (14) Thread Tools Display Modes
  11 links from elsewhere to this Post. Click to view. #1
Old 01-04-2009, 09:46 AM
Senior Member
moleculo has disabled reputation
Default Yaesu VX-8r mod - first on the internet!
This mod enables out of band TX on the Yaesu VX-8r.
Here's how to do it:
-Take out the battery.
-Under the battery is a heavy, thick plastic cover with very strong adhesive. Remove it using an XActo knife or a very small screwdriver that you can slip under it. This is the same cover you need to lift to install the Bluetooth option.
-After you get the cover open, it will look like this:
To mod the radio for out of band TX, locate the only resistor visible on the board, just to the left of the bluetooth plug:
All you have to do is carefully remove this resistor. I have a fine tip for my solder station for little work like this:
Make sure you clean off ALL the residual adhesive. Don't try to put back the cover that you took off, as it will be badly deformed and you will have lost some of the adhesive. Yaesu gives you several extra covers in the bottom of the box, so use a new one. This is important to preserve the waterproof integrity of the radio!
After you put the battery back in, the radio will have reset and you will lose all of your settings. I'm not sure what the complete range of TX is yet, but this mod definately opened it to TX out of the Amateur bands.
FIRST!
Worldwide Radio Forum
  #2
Old 01-04-2009, 04:22 PM
Happy_Hamer's Avatar
...{}/_\{}...
Happy_Hamer is on a distinguished road
Default
in PDF
__________________
That's how I roll!!
  #3
Old 01-04-2009, 09:44 PM
Junior Member
kf4lza is on a distinguished road
Default uh oh...
Darn, this mod is only a Mars/Cap mod not a freeband mod like on the VX-7R. I was hoping to open up TX into 47 MHz. It's a no go I am afraid. Hopefully there is a resistor to pluck for a freeband mod of some sort hopefully we can find it.
73's
  #4
Old 01-04-2009, 09:49 PM
Junior Member
KG6NSB is on a distinguished road
Default
Thanks for that info, LZA, before I voided my warranty!
  #5
Old 01-05-2009, 07:15 PM
Junior Member
fbwebdes is on a distinguished road
Default
Does anyone know what bands are opened up once this mod is completed?
  #6
Old 01-06-2009, 11:43 AM
Junior Member
nicoderm is on a distinguished road
Default
i tested frs,155/465 tx. works fine
thanks mole for the info
  #7
Old 01-06-2009, 08:05 PM
Junior Member
k8cix is on a distinguished road
Default Question: vx-8r mod. reset
The mod for the vx-8r for mars/cap says "after the battery is replaced the radio will reset and you will lose all your settings"
Question 1: Does the radio reset automatically or do you have to do a reset and which one?
Question 2: What settings are lost. Are the default settings intact or do you have to input ALL settings?
Roger, K8CIX
  #8
Old 01-06-2009, 08:26 PM
Senior Member
W5LZ is an unknown quantity at this point
Default
Q-1. It sounds like it ought to do the reset automatically. If not, do it manually.
Q-2. It sounds like anything you programmed into it will be gone. Writing the settings down before doing the mod sounds like a real good idea! Then reprogram it.
  #9
Old 01-06-2009, 09:49 PM
Junior Member
Default
it will reset it self and yes you do lose all your data.
Roger, K8CIX
  #10
Old 01-06-2009, 10:39 PM
Senior Member
Default
Yep, that's what it did to mine.
Reply
Bookmarks
Tags
vx 8r mods, vx-8r mod, yaesu vx-8r, yaesu vx-8r mod
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/radio-radio-related-modifications/31824-yaesu-vx-8r-mod-first-internet.html
Posted By For Type Date Hits
Yaesu vx-7r modifications This thread Refback 07-02-2009 02:17 AM 2
YAESU VX-3e modifications This thread Refback 06-14-2009 02:45 PM 1
YAESU VX 3e modifications This thread Refback 06-09-2009 07:16 AM 5
Yaesu VX-3 modifications This thread Refback 06-03-2009 06:07 AM 2
YAESU VX-3R mod This thread Refback 06-02-2009 06:17 AM 1
Out of band TX on the Yaesu VX-8r This thread Refback 05-02-2009 05:17 PM 55
Vx-8r mod This thread Refback 04-21-2009 09:37 AM 39
Vx8r mars mod This thread Refback 03-13-2009 08:23 PM 15
Vx-8r mars-cap mod. This thread Refback 03-07-2009 02:31 PM 76
Vx8r mod This thread Refback 02-25-2009 08:20 PM 22
VX-8R MARS/CAP mod This thread Refback 02-23-2009 09:57 PM 143
VX8R : Messages : 275-304 of 346 This thread Refback 01-15-2009 12:49 PM 4
VX-8r mod | Addictomatic This thread Refback 01-13-2009 09:30 AM 94
Yaesu VX-8r mod - first on the internet! - Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF This thread Refback 01-04-2009 10:12 AM 1
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.3.0
