Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
powerband rfx 75
Reply
LinkBack (1) Thread Tools Display Modes
  #11
Old 03-11-2009, 02:15 PM
my2995dx is on a distinguished road
Default
well my erf-7530 is bad have to find a new one emailed them but didn't hear back yet
Worldwide Radio Forum
  #12
Old 03-11-2009, 02:17 PM
Default
Quote:
Originally Posted by freecell View Post
is this a new one there making or the same rfx75 just different wording
  #13
Old 03-11-2009, 08:35 PM
Senior Member
formulamojo is an unknown quantity at this point
Default
It's the same...
__________________
MoJo
www.mojoenterprises.us
  #14
Old 04-01-2009, 07:52 PM
Junior Member
bikrric is on a distinguished road
Default Rfx 75 intall
I have installed these rfx75s in a few radios very nice although I purchased units from different suppliers and one was doa. Hard to get warrantied. (should say no warranty.)
  #15
Old 04-01-2009, 08:22 PM
Default
Quote:
i got two and both no output
  #16
Old 04-04-2009, 01:52 PM
johnecashflo is on a distinguished road
Default rfx 75 in cobra 29 capacitor voltage
can anyony tell me how important the c42 voltage is on the cobra rfx 75 mod..i intsalled all the parts as stated on cb tricks (a wonderful site..thanks for all the help)..the rfx 75 seems to be working fine..deadkey 10 swings over 130 on my cheap meter..the install call for a 3300 uf 16 volt capacitor in the place of a 1000 uf 16 volt..the problem is radio shack only has 3300 6.3 volts ..should i leave the original cap or replace it with the 3300 6.3 volt cap..what can happen if i dont get the right cap values..thanks for any help
  #17
Old 04-04-2009, 04:49 PM
Senior Member
Cityboy is on a distinguished road
Default
I did this mod and am somewhat impressed. I installed just a few minutes ago and got a dk= 5 1/2 and swings to 55-58w. With modulation set at 18-20% and swings 100%. I have not installed the 1000uf at j36 and 33ohm resistor on the other side. I am running at 13.8v and it pulling around 5-7 amps and it is getting very hot if you stand on it at all. I will install cap at j36 and resistor and get back to you. I think the 130w is way too much for a mosfet rated at 75w.
  #18
Old 04-04-2009, 05:18 PM
Default
did you change the cap at c 42? that is one of the things i am wondering about..i did ad the cap and resistor at j 36 ..im wondering about the voltage at c 42.. the only cap i could find at radioshack was a3300 uf 6.3 volts..calls for 3300 uf 16 volts ..the ? was will it blow the lower voltage cap...as far as the 130 watts i have a cheap meter its probably more like 100 watts im guessing
  #19
Old 04-04-2009, 05:28 PM
Sheepdog
bob smith is on a distinguished road
Default
Just get a RM KL203 amp and velcro the thing to your radio. 100-130 watts and much more reliable plus you can use it with other radios. Plus, you get a REAL deadkey of 20-30, not this 5-8 bullsnot.
  #20
Old 04-04-2009, 05:34 PM
74IN's Avatar
Supporting Member
74IN is on a distinguished road
Default
Whatta cheap meter.....
__________________
XDX74
Reply
Bookmarks
Tags
292 radio shop, powerband rfx75
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/radio-radio-related-modifications/32639-powerband-rfx-75-a.html
Posted By For Type Date Hits
Info.com - RFX75 - www.Info.com This thread Refback 07-24-2009 07:27 PM 1
Powered by vBulletin®
