Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
powerband rfx 75
Reply
LinkBack (1) Thread Tools Display Modes
  #61
Old 06-14-2009, 02:06 PM
1342 is on a distinguished road
Default
Quote:
Originally Posted by W5LZ View Post
What's the difference between 38-42 watts RMS and 75-80 watts Pep? Nothing, just bigger and less useful numbers in Pep, that will never tell you as much as those RMS numbers will without a LOT of converting back and forth. If big numbers is the whole point, fine, knock yourself out.
oh my god there is still intelligent life out here lol.great response thank you!
Worldwide Radio Forum
  #62
Old 09-10-2009, 01:53 AM
Junior Member
fingers is on a distinguished road
Default
question on the super tune? i see that you have to add a 1n914 diode in series with a 470 ohm resistor in place of r56 old resistor but is removed for the rfx75 instructions?
need your input
thanks
  #63
Old 09-13-2009, 06:51 AM
jazzsinger's Avatar
Senior Member
jazzsinger is on a distinguished road
Default
There is no such a thing as power/watts rms.for a purely resistive load AVG power is taken from the product of rms voltage and rms current.
So technically the P.E.P power is a far more meaningful measurement than any "rms power" measurement,with a pure sine wave the P.E.P power is 2.6 times the avg modulated power at 100% modulation or 4 times the avg carrier power.
Its not about big numbers its about technical accuracy.
As freecell has pointed out numerous times before,most semiconductor manufacturers rate their devices in P.E.P so it helps too know what the P.E.P power is if you wan't to avoid melting those rf power transistors.
  #64
Old 10-21-2009, 10:31 PM
941Texas's Avatar
Junior Member
941Texas is on a distinguished road
Default
how much drive from the radio does it take to make it work. i have a radio that does 500 milliwatts max. i wonder if that would work?
941
Reply
Bookmarks
Tags
292 radio shop, powerband rfx75
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/radio-radio-related-modifications/32639-powerband-rfx-75-a.html
Posted By For Type Date Hits
Info.com - RFX75 - www.Info.com This thread Refback 07-24-2009 07:27 PM 1
Powered by vBulletin®
