Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
Motorboating noise when i transmit. What's up?
Reply
  #1
Old 03-27-2009, 10:16 AM
Damo666 is on a distinguished road
Default Motorboating noise when i transmit. What's up?
Hi. I have an old Binatone uk fm cb that motorboats when i tx from channel 35 to 40 but not on the lower channels. It motorboats gradually worse as i go from 35 to 40, but doesn't do it when i turn the rf power down. In addition to this, it only motorboats for about 5 secs, the s meter fluctuates then it settles. Any ideas on what the fault could be please? Cheers.
Worldwide Radio Forum
  #2
Old 04-15-2009, 11:16 PM
Junior Member
Larry_K5LZ is on a distinguished road
Default Pulling too much current.
Sounds like to are trying to draw more than your power supply can give, try a different one with a higher rating, ie 10 amps compared to 4 amps.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
