Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
Looking for cobra 1000 mods
Reply
  #1
Old 07-16-2009, 10:40 PM
941Texas's Avatar
Junior Member
941Texas is on a distinguished road
Default Looking for cobra 1000 mods
I have just purchased a fair cobra 1000. i would like to do the rc/npc mods along with the channel mod. or really just any useful mods you may have. i have googled my brains out trying to find any info. can anyone point me in the right direction on where a good list of 1000 mods are.
thanks 941
Worldwide Radio Forum
  #2
Old 07-16-2009, 11:06 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
VR 6 for modulation adjustment - or cut D16 to disable limiter. Personally, I would just adjust VR 6 and leave the limiter intact. Especially if you are going to use a D104 power mic - or equivalent.
L17, L16, and L13 for AM power output.
And - of course - if you haven't done these mods before; then send it to a shop to get it done.
My first base station was a Cobra 1000GTL. I liked it and had a lot of fun with that radio.
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 07-16-2009, 11:09 PM
941Texas's Avatar
Junior Member
Default
thanks for the info. do you know if there are any receive mods or swing mod for this radio?
941
  #4
Old 07-16-2009, 11:22 PM
Rob KI6USW's Avatar
Senior Member
Default
Quote:
941
I never had the chance to do that mod with this radio.
I'm sure someone here might know where to replace that one receive amp transistor with a Sanyo 2SC2999E - and the noise blanketer/recieve sensitivity diodes with the four replacement 1N6263's. But I don't have the location numbers for them.
__________________
What gear do I use?
  #5
Old 07-16-2009, 11:34 PM
MisterFatty's Avatar
Senior Member
MisterFatty is on a distinguished road
Default
Chassis is the same as the 89GTL, Late Zach T, 87GTL, and pretty much the 29GTL. Technically speaking there is no public NPC-RC mod. However you can get virtually the same effect by using the so-called SuperTalk. I have an 89GTL which will vary DK from about 50MW to about 9W, and maintain the same PEP output (35+ from what i remember). You can probably compare locations with a 29GTL for Shottky/2999 mod....
10k Pot can be subbed in place of the RF Gain, or you could use different resistances on a 3 position switch for a H/M/L type arrangement
Edit: BTW, this chassis is a real screamer setup properly...
  #6
Old 07-17-2009, 06:16 AM
941Texas's Avatar
Junior Member
Default
thanks guys, this info will get me going in the right direction. the radio should get here in the next couple days. i cant wait to play with it. i will post my results.
941
  #7
Old 07-18-2009, 08:44 PM
loosecannon's Avatar
Senior Member
loosecannon is on a distinguished road
Default
941,
just looked at the schematic for this radio and here are some places to start modding.
for the receiver: buy the 2SC2999/ 1N6263 receive kit off of ebay. they should be easy enough to find for under 10 bucks.
replace TR2 (2SC1674) with the 2SC2999 transistor.
replace D6, D7, and D28 with the diodes that come with the kit.
as for the "NPC" mod, i think what you mean is a "swing kit" which does reduce the carrier while maintaining the max modulated wattage that the radio has when peaked.
it is indeed R49 that you want to remove and play with the value of to set the dead key where you want it.
if you want to do the variable thing that is just fine, but if you want to set the deadkey where you want it and leave it there, just increase the value of R49 until you get what you want.
the stock value is 4.7ohms. so buy a 5.6 ohm, a 6.8 ohm, and a 10 ohm 1/2 or 1 watt resistors, and see what deadkey they give you.
the trick is to tune up the radio before you do the "swing mod".
first turn up the modulation pot, then, while saying "teeeesssst" (test) into the mic, tune the tuning coils listed above for max PEP wattage on your meter.
when that is done, then play with the value of R49 and set the deadkey where you want it for your amp.
if you are not running an amp, then there is no reason to play with the deadkey.
a swing kit does not give the radio anymore modulated power, it only reduces the carrier while maintaining what the radio already has.
as for the capacitor that is used in the swing mods, im not really sure why that is used, as once the carrier is present, the anti-spiking diode is already forward biased, and the modulation comes through 1:1.
maybe someone can explain the use of the cap to me as there is lots i dont understand about this stuff yet.
after doing these mods, and giving the radio a full alignment, it should be one bad ass radio.
good luck,
__________________
"Man shall never reach the moon, for such a quantity of gunpowder would be needed as to gravely injure the crew."
~ Children's Encyclopedia, 1926
  #8
Old 07-25-2009, 07:43 AM
941Texas's Avatar
Junior Member
Default
i have all this great info and still no radio to use it on. some people are really slow on shipping.
941
  #9
Old 07-28-2009, 08:33 PM
941Texas's Avatar
Junior Member
Default
well the radio finally made it. not very clean but oh well. did the rx upgrade. scoped the signal from a generator before and after. very little change. now with noise and the anl there was a very noticeable change before and after. so now on to the power mods.
as is the radio is dead keying 5 watts and forward to 5.5 with a whistle. lets see how we can improve on this.
941
  #10
Old 11-06-2009, 04:52 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
Quote:
Originally Posted by loosecannon View Post
941,
good luck,
The cap usage is a god question LC ? Most of these cap/resistor mods have always been done on AM radios with the jumper removed then the cap then the resistor (variable) until the DK is what your looking for. (There are many variables that can be used concerning the cap/resistors as well) I have had very little experience with the Cobra 1000s or the Uniden Zachary T's .
although as stated , the Cobra 1000s are using a resistor and not a jumper from the get go. So why no cap used on these ? or would it be by modders choice here ? Many years ago , I used Mr Fatties (I think I first saw on it Plow Boys site , (may geocities rest in peace) tip mod , they worked very good but I really didn't see much difference between a nice healthy cap and a 1 watt resistor used , and plus they were alot less work compared to the tip mod's.
Kind of reminded me of the old Retards swing kit they were always pushing with a tip. You can even put a variable trim pot in the radio that will work like a variable on the radio , IM not sure what the right name is for those ? there either a variable cap or variable resistor. (little blue guys with a little white button you can adjust)
Your question is a good one. But many of us know what techs (some) think about swing kits to begin with. Oh well. oh , they also seem to use the cap with the tip mods.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
