Put a 50K ohm pot in series with one of the lamps. Adjust it to where you like it to be. Take the pot out and check the resistance in the pot where you liked it with a VOM. Substitute suitable resistor for the value found on the pot/VOM meter.
Dos centavos...
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
