Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > RADIO AND RADIO RELATED MODIFICATIONS
Amateur Callsign Lookup
Enter Callsign:
Testing New Tweety Birds
Reply
  #1
Old 10-13-2009, 11:02 AM
Wire Weasel's Avatar
Honkus Maximus
Wire Weasel is an unknown quantity at this point
Default Testing New Tweety Birds
Alright, have all the parts and building 1st one today. Will need to test. Was going to put one in my Synchron desk mic which is the Turner duplicate mics...put can't seem to get the thing apart. Has 4 screws on bottom. Also removing the nut holding the volume control to the base, but after all this the bottom is still being held to the base rather securely by something else that I can't see. No more screws on anything obvious.Did a little prying around the edges...can't figure that out.
So still would like to test the tweety. I can supply 9 volts to it. If I connect the output to am 8 ohm speaker...will the circuit produce enough signal to be heard over the speaker at all? Or is it such a small signal that it must be fed into a radios audio circuit to get amplified?
Thanks for any help!!
Again, if successful, I will be offering them here to anyone who wants them.
TNX WW
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
Worldwide Radio Forum
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GAME ON !!! Tweety Bird ala WW Wire Weasel Meters, Mics & Other Accessories 9 11-15-2009 01:43 PM
FCC Denies Petitions to Bring Back Morse Code Testing Sonwatcher FCC & ARRL Activity 0 02-29-2008 06:26 PM
Marconi testing the Starduster, I-10K, Wolf Radio .64 Marconi CB Antennas 6 05-06-2006 06:25 PM
Antenna Testing Event in Southern CA! Master Chief CB Antennas 47 04-17-2006 09:44 AM
Powered by vBulletin®
