Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Satellites & Space Communication Topics
Amateur Callsign Lookup
Enter Callsign:
Made my first HT satellite contacts yesterday - fun!
Reply
  #9
Old 07-12-2009, 07:14 PM
Moleculo has disabled reputation
Default
Quote:
Originally Posted by Sonwatcher View Post
I have a 2m/440 yagi on the roof on a rotor. Is it possible to use this setup ?
Yes, although you're going to need to either change your rotor to one that you can adjust the elevation on, or figure out how to make it adustable manually. The polarity could be an issue, too...but you should be able to make contacts.
I JUST made a few contacts again on the pass that went over a few minutes ago. This is too much fun!
  #10
Old 07-13-2009, 03:32 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Congrats Mole!
I remember one of my first contacts. It was feild day. Was on Ao-10 or 13. Can not remember which bird. Made a contact to Japan. Lasted about 30 seconds. Man them high orbits were fun. But many years ago.
I work a lot on AO-7 now. FM sats are nice but ssb is a trick.
As far as the LEO birds the polarity is not as important. I have worked them with omni antennas just fine.
I run Yaesu 726 and 736 rigs.
Anyway here is a pic of my homemade sat antennas.
  #11
Old 07-13-2009, 11:16 AM
Default
Here's a good detailed project build for a handheld yagi and duplexer:
http://www.wa5vjb.com/references/Che...ennas-LEOs.pdf
And here's another cheap build:
Homebrew Arrow Antenna
And another using PVC:
VE2ZAZ - Arrow-Style VHF/UHF Portable Satellite Antenna
Turnstile antenna for home station:
2 Meter Turnstile Antenna For Amateur Satellite Communication
  #12
Old 07-13-2009, 11:35 AM
Radio Tech's Avatar
Radio Operator
Default
The turnstyles work ok. I have used the "Texas Potatoe Mashers" quite a bit. The biggest problem is when the bird is low on the horizon. That is when the yagi has advantage.
  #13
Old 07-17-2009, 12:06 PM
Default
I was able to get on again last night and made a few contacts on A0-51 again. I'm going to start trying a few of the other birds also. I'm terrible at remember the call sign that was just spit out rapidly at me so I can call it back, though. No matter...it's still a lot of fun. I got a 440Mhz preamp kit in, so I'm going to work on putting that together to make the RX even better.
  #14
Old 07-17-2009, 12:42 PM
Radio Tech's Avatar
Radio Operator
Default
mole,
Are you only on the FM birds? If so, wait till you work a ssb bird. Now that is a blast also.
Now, I will not question you ability or anything but I have to ask this. If you are using FM only then why the preamp? Reason I ask this is because I have been using sats for a long time. And have not used a preamp since the HEO birds were up. Now not saying they will not hurt but if you are receiving a noisy signal then a preamp is only going to amplify the noise.
I started in sats before I even had my ticket. A freind of mine got me to go to feild day with him in the early 80's. We used seprate radios to work the birds. The UHF up link antenna was a home brew 64 element. (which I still have) The VHF was a 24 element. Back then we ran 400 watts uplink and ARR preamps. They were GaAsFET and high dollar back then. The rigs were single band units.
I got my ticket and my first sat rigs were the Yaesu FT-221R 2 meter all mode and a KLM Echo 70 with added crystals. I later picked up a KLM multi 2700 tranciever. That has 2 meter all mode with a 10 meter receiver built in. That was one of the first rigs designed for sats. It was great for the old spunknic birds and also when AO-7 started.
I now have 2 Yeasu FT-726 rigs and a Yaesu FT-736. I do not have a 1.2 gig module but I work all other modes. No amps and no preamps.
Oh, sorry for hijacking your thread with my boring history....
but here is a pic of the old 64 element. It was cut back a year ago for EME.
  #15
Old 07-17-2009, 01:13 PM
W9WD
Guest
Posts: n/a
Default
Was your EME successful?
  #16
Old 07-17-2009, 01:26 PM
Default
RadioTech, that's not a thread hijack
Right now I'm FM only and am only doing it with an HT and the handheld Antenna (which is why it's FM only). Maybe if I get a Yaesu FT-817 someday I'll be able to try SSB mode using the handheld.
I'm not getting a noisy signal, but I was considering the advice of N1ASA in that document I attached to try a preamp if you're using a handheld antenna. I figured that if I could find one cheap enough that delivered 15-50db gain and only 1db or so of noise, then that would be worth a try??
I have a 2m 35 watt brick amp, too. I might try putting 20 watts or so into that Arrow antenna to see what kind of difference that makes also
Reply
Bookmarks
Tags
handheld satellite, leo, satellite
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/satellites-space-communication-topics/35027-made-my-first-ht-satellite-contacts-yesterday-fun.html
Posted By For Type Date Hits
antenna turnstile | VIRGILIO Ricerca | Web This thread Refback 11-22-2009 12:59 PM 2
Powered by vBulletin®
