Go Back   WorldwideDX Amateur Radio Forums > Misc. Radio Related > Scanning & Shortwave Listening
Amateur Callsign Lookup
Enter Callsign:
Grounding a Par end fed antenna
Reply
  #1
Old 12-22-2011, 03:13 PM
Junior Member
cloud9 is on a distinguished road
Default Grounding a Par end fed antenna
I have a Par end fed antenna and I would like to no witch ground lead 1 , 2 or 3 do I use on the matchbox to ground to a copper pipe ? I am using a Sony 2010 .
  #2
Old 12-22-2011, 04:38 PM
BJ radionut's Avatar
BJ radionut is on a distinguished road
Default
First, you have several options on how to hang the antenna. Choices range from horizontal, sloper, inverted-L, inverted vee, or even as a vertical.
Next, you have to decide how you are going to configure the ground, and this will vary from installation to installation. We were able to use the factory default configuration -- connectors #1 (SO-259 shield) and #2 (ground lead of the antenna side of the 9:1 transformer) shorted. Basically, this leaves the connection to the antenna ungrounded and the user should ground the receiver in the shack.
Even though we did not observe it during our test, this installation may pick up man-made noise. If this is the case, you can also take the short between connections #1 and #2 out and ground one or both of these connections (#2 direct to ground and #1 grounded back to the receiver). This installation works very well in noisy environments from man-made sources.
MT What's New
Link is complete review and install article from Monitoring Times Magazine
All the Best
BJ
__________________
Yaesu FTdx3000-Yaesu FT-950-Yaesu FT-817 portable and mobile w/HLA300
"A dime in the antenna is worth a dollar in the transmitter any day"
  #3
Old 12-23-2011, 07:50 AM
Junior Member
Default
MT What's New
All the Best
BJ
Thanks for your answers radionut .
What do you mean by taking the short between connections #1 and #2 out and ground one or both of these connections (#2 direct to ground and #1 grounded back to the receiver). I am new to all of this so can you explain how this is done and also how do you ground the receiver ?
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
CB Radio - Antenna Basics: Choosing an Antenna Robb CB Antennas 5 07-28-2011 05:19 PM
CB Radio - Antenna Basics: Part 1 Robb CB Antennas 14 01-26-2010 07:40 AM
CB Radio - Antenna Basics: Part 2 Robb CB Antennas 0 01-06-2010 03:37 PM
The ARRL Letter Vol. 27, No. 16 April 25, 2008 AudioShockwav FCC & ARRL Activity 0 04-25-2008 04:27 PM
Powered by vBulletin®
