Go Back   WorldwideDX Amateur Radio Forums > Misc. Radio Related > Scanning & Shortwave Listening
Amateur Callsign Lookup
Enter Callsign:
Aircraft Receiver
Reply
  #1
Old 12-17-2007, 07:51 PM
Cat Driver's Avatar
Senior Member
Cat Driver is on a distinguished road
Default Aircraft Receiver
Where can I find a 1/2 way decent aircraft only receiver that doesn't cost an arm an a leg. 108 to 136 mhz I think.
Thanx,
Cat
__________________
Ronnie-The Toolman
CB Handle--Six Pack
Lake of The Ozarks
  #2
Old 12-17-2007, 10:57 PM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
You can get a scanner that will cover the civilian airband dirt cheap on Egay.Most scanners that I have owned reveived good on the airband.You may also look into an aviation transceiver that will scan.These two air scanners also cover the AM/FM broadcast band:
Air-Scan V Features
Aviation Interrupt
powered by 115 volt power adapter (included)
or (6) C batteries (not included)
3 scan modes
dual-level priority
5 priority aviation memory locations
rubber-duck antenna with aviation compatible BNC connector
large ferrite bar for improved AM reception
separate telescoping FM antenna
low battery indicator
external power jack
external stereo speaker jack
external stereo headphone jack
AM band 530 – 1630 kHz
FM band 88 – 108 MHz
Aviation Band VHF 118 – 142.975 MHz (8.33 kHz spacing)
squelch & volume control knobs
overall measurement 10"l x 7"w x 3"h
patent pending
5-year warranty
Features: 3 scan modes - 5 priority aviation memory locations - backlit screen - flexible antenna with aviation compatible BNC connector - lightweight; only 12.7 oz. - low battery indicator - external power jack - external speaker jack - AM band 530 - 1630 KHz - FM band 88 - 108 MHz - Aviation Band VHF 118 - 142.975 MHz (8.33 KHz spacing) - single-hand squelch control - 6 5/8”h x 2 3/8”w x 1 7/16”d - 5-year warranty
I hope this helps.
Carmen
  #3
Old 12-18-2007, 06:35 AM
Cat Driver's Avatar
Senior Member
Default
Where can I find that base unit on top there?
I guess I'm hunting one that scans the whole a/c band without having to program all of the freq's in to it.
Cat
__________________
Ronnie-The Toolman
CB Handle--Six Pack
Lake of The Ozarks
  #4
Old 12-18-2007, 06:15 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Most scanners will cover the VHF aircraft band, some will cover both VHF and UHF. Guess it just means shopping to find the one with the features you want. Basic requirements are the bands desired and the ability to use AM mode. After that it's more a matter of which suit$ you best.
One way to get around programing in all the frequencies is a scanner that scans between an upper and lower band edge. Just two things to program in with that type of thingy.
  #5
Old 12-18-2007, 07:02 PM
Cat Driver's Avatar
Senior Member
Default
How about one of the better bearcats? I didn't know you could program one to scan the whole band, but that is what I was really after I guess.
Thanx, Ron B.
__________________
Ronnie-The Toolman
CB Handle--Six Pack
Lake of The Ozarks
  #6
Old 12-18-2007, 10:54 PM
Default
I'm not really that familiar with Bearcat scanners so really have no idea of what they are capable of. Best suggestion is to read about a few of them to get an idea of what's 'normal' for them. It also depends on how you plan to use the thingy. I can tell you that unless you are on a major airway, or near an airport, you aren't gonna hear gobs of things going on all the time. Not a lot of chatter from planes, in general, like there is from control centers, flight service stations, etc.
Good luck...
  #7
Old 12-19-2007, 04:41 AM
Cat Driver's Avatar
Senior Member
Default
Thanks alot Doc. I might call BC today an see what I can come up with.
I have an outside base antenna, an I am only about 5 miles from the airport.
Ron
__________________
Ronnie-The Toolman
CB Handle--Six Pack
Lake of The Ozarks
  #8
Old 12-19-2007, 05:18 PM
Ronin is on a distinguished road
Default
Just a thought,...take a look at the Radio Shack Pro-83 handheld scanner. They were recently discontinued by R/S, but you can still find them new in the package on ebay by people who bought up their stock. I have seen them sell for about $70 or less brand new.
I have had a Pro-83 for about 2 years and it's really nice! you can program individual memories as well as scan/search the entire aircraft band (as well as other bands like public service, 2 meter and 440 ham bands, marine band, etc).
It takes 2 AA batteries runs about 16 hours on rechargable batteries (2500mah NiMH) or about 24 hours on AA alkalines. There is a micro switch in the battery compartment which will allow you to charge the rechargable batteries through the radio.
What really sold me was the display is very easy to read and the backlight for the display and keypad is a bright orange, plus it is very easy to program.
Just giving you something else to think about.
Descisions,..descisions!! Lol!
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/scanning-shortwave-listening/28129-aircraft-receiver.html
Posted By For Type Date Hits
am aircraft receiver | VIRGILIO Ricerca | Web This thread Refback 05-08-2009 01:19 AM 1
Powered by vBulletin®
