Go Back   WorldwideDX Amateur Radio Forums > Misc. Radio Related > Station & Mobile Pics
Amateur Callsign Lookup
Enter Callsign:
Just finished building my new radio desk.
Reply
  #1
Old 09-08-2010, 05:05 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default Just finished building my new radio desk.
Last year I started to rebuild my shack starting with new flooring and a new paint job. I also decided to do something about the radio desk which I was outgrowing.Adding a Kenwood TS-820S with matching VFO, speaker, and tuner to a Heath DX-60/HR-10 AM station meant that I had far too small of a desk and since there was not much available in the way of ready made stuff that suited me I decided to build my own. Some of you may remember a thread I started about converting an RCA broadcast TX to 80m AM that fizzled when the modulator blew up and fed 3100 volts back straight to the audio predrivers wiping out everything in it's path including the mod transformer. It was then that I decided to scrap the TX and look down the road at building an amp and maybe using the steel side panels to build an operating desk. The desk was finished this afternoon except for a couple pieces of trim yet to install.It is 74 inches wide by 32 inches deep with a shelf 12 inches above it measuring 74 wide by 16 deep. These were made from the 1/16 inch thick steel side panels from the old broadcast TX which are formed panels 1 1/2 inches thick. you can see them in this picture of the TX laying on it's side.
I had to cut down one end to allow a wood panel to be inserted in the end to finish the underside.You can see where I removed about a quarter inch from the right hand side.
Next I planed down some 2X4's to fit inside the panels to add some strength and attachment points for the legs and shelf and to allow something to attach the side trim panels too.
Here you can see where I removed the 1/4 inch or so of the steel panel to be able to insert the stained oak plywood panel underneath.
Inserting the oak plywood panel.
Plywood trim panel secured with screws thru holes that were already in the steel panels. The legs are 3/4 oak plywood stained with Minwax "Special Walnut" stain. The 1/4 inch plywood used for underneath is stained the same color.The black angle iron brackets are from an old bed frame cut to size and painted gloss black.The tie piece across the back is solid oak.
The finished product in the radio room awaiting the reinstallation of gear. The desktop does not sit on the file cabinets but rather about 1 1/2 inches above them.
Finished product with shelf installed. I used dowel pins on the bottom of the shelf legs to prevent the shelf from moving. The shelf is very heavy and strong because it has to support all the Kenwood TS-820S station gear plus future boat anchor stuff like the DX-60 transmitter and whatever else I may acquire.
All I have yet to do is cut and stain a couple pieces of oak trim to cover the ends of the panels of the desktop and shelf. I have some perfect oak planed to about 1/2 to 5/8 of an inch just waiting to be cut to size and stained. I will install them using furniture type fasteners that have a hex head and screw into a captive nut set into the ends. Time ran out today and I go back to work tomorrow but hopefully Saturday I will begin the process of laying out a new station configuration and possibly get started on the remaining trim pieces.
__________________
There are 10 kinds of people in this world. Those that understand binary and those that don't.
  #2
Old 09-08-2010, 05:15 PM
Senior Member
nat19 is on a distinguished road
Default
Looks really good!!
__________________
Base: Uniden Washington, Turner +3 and maco 5/8.
Unit 254 Central West Virginia
  #3
Old 09-08-2010, 05:37 PM
CTStallion's Avatar
Senior Member
CTStallion is on a distinguished road
Default
Looks GREAT! Nice job making the shelf high enough to put even even the largest transceiver below it, and strong enough to hold the boatanchor(s), amp(s), or whatever other goodies you have instore.
__________________
Icom, Heathkit, Ameritron & MFJ HF Gear
Kenwood, Yaesu, & Alinco VHF/UHF Gear
Ranger, Galaxy, Uniden & Cobra 10 - 12 Meter Gear
Ten-Tec 'T-Kits' (love the lil buggers!)
Lotsa Homebrew & Tube Gear
Homebrew Antennas (HalfSquares, Bazookas, Wire Arrays) HF & 6M
Shakespeare ABS-1600 Army Stick 10 - 12M
Hustler & MFJ VHF/UHF Antennas
  #4
Old 09-08-2010, 05:45 PM
Default
Quote:
Forgot to say that the shelf legs sit directly on top of the desktop legs to transfer the weight straight down better. The shelf is 12 inches above the main desktop and each shelf leg is 18 inches in from the end. That was by design. I have a cabinet that measures 17 inches wide by 10 3/4 inches high and will eventually house a small homebrew 811A or 572B amplifier and Retro-75 AM transmitter and will go at one end of the desktop.
__________________
  #5
Old 09-08-2010, 06:58 PM
Senior Member
bioman is on a distinguished road
Default
oh man that looks GREAT in comparison to my efforts......
all my "desk construction" projects seem to consist of 2X6s and 3/4" oak plywood built "mission style"
pics of my desk here my shack
__________________
cdx-1557 reading pennsylvania keystone state
REAL radios glow in the dark
  #6
Old 09-08-2010, 07:15 PM
pro151's Avatar
Supporting Member
pro151 is on a distinguished road
Default
Nice. Very nice!
__________________
MASTER TROLL
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
  #7
Old 09-08-2010, 08:39 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Sweet! Looks like you'll have enough room for a while. My handicrafting is similar to what Bioman is talking about.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #8
Old 09-08-2010, 10:15 PM
depark's Avatar
depark is on a distinguished road
Default
That look AWESOME!!! I like the craftsmanship of the work. I wish I had something like that.
__________________
73 Darryl VA7DTP
Portable: Yaesu VX-8DR
Mobile: Yaesu FTM-350R & Comet CA-2x4SR
Base: Icom 746Pro & Chameleon V22L Multiband antenna
MFJ-993B Auto Tuner / RigExpert Ti-5
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to choose your first Ham Radio Moleculo General Ham Radio Discussion 6 12-16-2009 03:52 AM
Used CB Radio: How to Buy-Part 1 Robb General CB Services Discussion 5 11-30-2009 06:50 PM
The ARRL Letter Vol. 27, No. 16 April 25, 2008 AudioShockwav FCC & ARRL Activity 0 04-25-2008 04:27 PM
The ARRL Letter Vol. 26, No. 46 November 16, 2007 AudioShockwav FCC & ARRL Activity 6 11-28-2007 07:55 AM
Mag delta force problem.. Splash1 CB Band and CB Radios 9 02-03-2007 12:49 AM
Powered by vBulletin®
