Quote:
Originally Posted by DoctorAudio I've never understood how a circuit that just raises and lowers the static carrier lever in conjunction with the loudness of the modulation ever got named "negative peak compression" True negative peak compression works independantly of the carrier level. On a standard AM transmission, the carrier doesn't change amplitude. The sideband energy is what causes the envelope growth. The only reason the carrier doesn't pinch off with the so called "NPC" mod is because the modulator in any given CB radio is only capable of a finite amount of audio drive. When the NPC mod raises the static carrier level to maximum on high voice levels, it's merely driving the carrier too high for the limited audio available to modulate the transmitter to beyond 100% |
That is NOT what is happening! If the negative peaks were not compressed and you modulate the positive peak as much as possible--but still below the saturation level--the negative peak would severly clip. The NPC components, normally just a single diode and a resistor, causes the gain of the modulation circuit to lower during the negative peaks. That is, the more modulation, the less negative peak gain. This causes assymetrical modulation with very nice shapped sine-wave type peaks on both the negative and positive peaks.
What a lot of "so-called" techs have to say is the the negative peaks are trashed, pointing out that they are "thick" in the middle of the modulation envelope. What they do not take into consideration is the fact that if you have the same number of peaks in the positive direction as you do the negative direction. the area that they occupy will be different for the negative peaks than it is for the positive peaks. Of course the center will look thicker because there are so many negative peaks that are compressed into that small area of the screen.
This simply shows that the compression circuit is working properly.
As stated already, the actual carrier does not change as modulation is applied. This can be seen on the spec-an. However, the term amplitude modulation came about because the early fathers of this science thought that the amplitude was being varied in accordance to the modulation applied.
using this idea simply as a teaching tool, it can be seen why they believed this to be so and there are many ham radio operators, and many more
cb techs that still subscribe to this erronous thinking.
as modulation is applied to the carrier the carrier "seems" to expand during the positive peaks and go to zero size during the negative peaks.
With NPC-RC (RC = reduced carrier) the negative peaks hit about 98 percent modulation at the same time as the positive peaks PEAK OUT at somewhere above 200 percent.
The compressed negative peaks do not cause clipping and since compression takes over for the limiter, which is removed, there is no problem removing the limiter since compression does a better job anyway. Removing the limiter allows the positive peaks to reach their maximum usuable value WHICH IS JUST BELOW THE SATURATION POINT!
I gotta go--more later.
BILLY DEAN WARD
