<blockquote>
Quote:<hr>...if you go full CW you start getting the lag at zero and clipped pos. peaks.<hr></blockquote>
Do you mean using a tone (bypass the mic gain), you get the lag and clipped peaks? That would be the same as what the pics I posted showed, except the peaks weren't clipping. I'd still like to see the video clips...if you can't get them hosted, you can email them to me and I'll host them.
What's "wrong" with the pattern you posted is that it's not symmetrical, which is usually the way a "normal" properly modulated
AM signal looks. An NPC pattern can't be symmetrical by definition. There are quite a few hams, as well as some broadcast stations that do the same type of thing on
AM as Justin said, but they don't do 200% modulation. On any good receiver the AGC would kick in and the received signal would start clipping well before it got to the 200% modulation point. Of course nobody ever accused a
CB or export of being a "good receiver"!!!! So I guess what's "wrong" with it is more a question of what you're trying to achieve. If you want that much modulation, then I guess nothing is "wrong" with it.
A big problem with a lot of these
CB NPC mods is that they mess up the radio elsewhere....
I still like Concrete's idea of taking the time division out of the pics...
</p>
