| | | Notices | Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar. | | Tech, & Repair Before you do anything, read this.!
The modifications are not verified and tested by The WorldWide Radio Forum , so if you try some of the modifications, it's on your own risk.
Performing modifications of some equipment may be a violation of local laws. If you have any doubts, do not perform the modification. |  | |
03-29-2004, 02:42 PM
| | | CB trouble shoooting and modification tool Hi All,
I am now into software developement, so I thought that I would make an application to assist people with CB radio troubleshooting and modifications, it is called "Defpom's CB Radio Simulator", I designed it to make it easier to diagnose problems with CB's and also to aid with frequency modifications.
It is still a work in progress, and is under continued developement, so I would be happy to hear any ideas people have for features to add to it.
Download a copy and try it out, it works in Windows 98,2000, NT, and XP, along with MacOS8, OS9, OSX.
You can go to my software section by clicking on the "S&M Software" button in the menu of my website.... www.radiomods.co.nz/
The Defpom www.radiomods.co.nz/ www.TheDefpom.com www.radiodiagrams.com</p> |
| | | Re: CB trouble shoooting and modification tool Defpom,that is some real good software!!! that is gonna come in handy for sure!!! I'll give it a A+ all the way!!! Keep up the good work!!!!  007 in Central Maine said that!!!  </p> |
04-01-2004, 12:31 AM
| | | Re: CB trouble shoooting and modification tool Hi,
Thanks for your comments, I currently have a small troubleshooting section in the members area of my website, I may well include that information as part of the programme, along with a general troubleshooting guide for comon (and some not so common) problems.
I have just released a beta of 0.1.4, (web site download only) for Windows machines as it was mainly to address some problems poeple had with older Windows versions, but it does have a couple of new features, so please take a look incase it gives you any more ideas for new features to add, I am open to any suggestions, good ones will be added if possible.
If you have the current version 0.1.0 you can do a "check for update" and download it directly.
04-12-2004, 10:02 PM
| | | Re: CB trouble shoooting and modification tool Hi People,
I have just released version 0.1.5, which supports many more PLL's, it now has a PLL database, CB channel frequencies and other enhancments....
08-21-2004, 09:35 PM
Looks like you got a good start so far with this.
</p> |
</p> |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 03:12 PM. |
