pull the mod kit, restore the circuit and the amc if it has been removed. make sure to double check the wiring of the echo board against the instructions and return any grounds to the mic connector ground, do not use the cans as solder-ground points. also note whether the proper voltage is being used to power the echo board, some will run at 13.8 and others require 8 volts. also do not use the dc ground connection for power if the audio shield grounds are used as this will create a ground loop causing instability in the echo board. use either the stock mic that was included with the 949 or add a CDL56KDX1. a straight-forward alignment should yield approximately 25 - 30 Watts PEP from 6.25 - 7.5 Watts of Carrier, respectively, 30 - 35 Watts PEP on
SSB. if none of this is any help, have a couple of beers and start shopping for a tech.
