| Home | Register | Chat Room | FAQ | Social Groups | Member Map | Search | Today's Posts | Mark Forums Read | Satellite Maps | DXSpot Map |
| | LinkBack | Thread Tools | Display Modes |
#1
| Hi all I am looking at an HF rig thats forsale for fixing or for extra parts for the one I have now. The guy said he was on 20 meters then the electricity went out and the radio never came on again??? WHAT do some of you think??? its a Yaesu FT-840
__________________ """"was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away"""" |
| Worldwide Radio Forum | |||
#2
| the power to the radio is switched through a 10amp double pole relay inside the pa block, check the relay is switching and applying voltage to test point 5002, if you have voltage there the relay is doing its job, good luck...
__________________ ![]() The antenna incorporating the present invention reduces by about fifty to eighty-five percent the lateral or radial space required as compared to a quarter-wave or five- eighths wave groundplane antenna while simultaneously providing better gain than a five-eighths vertical antenna. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
