I would like to try this to get a higher dead key.
1) Add a 4.7K ohm resistor (1/4 watt) from the positive side of C116 to the gate of the ERF-2030 (this is the left-most leg when looking at the face of the ERF-2030).
2) Remove the capacitor at C62, and replace it with a 390pF capacitor. Also, make sure that there are no additional capacitors tacked on the solder side of the PCB (sometimes Cobra adds additional capacitance at this part to get everything to tune-up correctly). If there is an additional capacitor on the solder side at C62, then remove it.
3) Remove diode at D8, and replace it with a jumper. Or, just add a jumper wire across D8.
We have had good success with these additional steps and it gives everyone the carrier level that they are looking for."
My Question is when you Remove the capacitor at C62, and replace it with a 390pF capacitor. The new Capacitor is 390pf but how many volts.
