Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
Galaxy DX 88HL HELP!!!!
Reply
  #1
Old 11-29-2007, 01:10 AM
Junior Member
hank is on a distinguished road
Default Galaxy DX 88HL HELP!!!!
Intermitant loss of out put power radio keys but only does 1/4 of a watt has audio checked driver and finals voltage reg. ect: ALL check ok. Sometimes it works ok swings 40 watts other times keys up has audio but wont do any watts.
BEST REGUARDS HANK
Worldwide Radio Forum
  #2
Old 11-29-2007, 09:40 AM
Galaxy Tech
GRTS is on a distinguished road
Default Re: Galaxy DX 88HL HELP!!!!
Quote:
BEST REGUARDS HANK
Repairing any electronics is 60% symptom analysis (recognizing what's not working) and 40% troubleshooting.
So just knowing exactly what's not working is over half the battle.
Below you'll find enough info to repair any Galaxy radio with good receive and no transmit power.
You only need two things for these radios to produce power.
1. Proper voltage
2. Proper drive.
Checking proper voltage is easy with only needing a voltmeter.
Since you are testing the transmit section always make sure your voltage checks are done in TX mode.
Make sure front panel controls are properly set before testing, Mode SW - AM, RF Pwr button to HI, etc...
Key radio and check collectors of TR51 (2SB754), TR44 (2SC2166), TR43&TR56 (2SC2312) all for approx. 6.5 volts.
Checking for proper drive is a bit more involved and requires a good 100Mhz scope with a (x10) scope probe.
Below are the AC/RF voltages peak to peak starting from TR45 out to the antenna.
TR45 collector - 10v peak to peak in TX.
TR44 collector - 15v peak to peak in TX
TR43/56 collectors - 25v peak to peak in TX
Output side of L33 - 80v peak to peak in TX
Output side of C166 - 40v peak to peak in TX
Output to antenna - 60v peak to peak in TX
If you do not have the approx voltages at TR45 then you must troubleshoot the transmit oscillator circuit of X4 (10.695mhz) crystal and TR30.
In transmit check the emitter of TR30 for 10.695mhz.
Next check IC3 pin 7 for 10.695mhz in TX.
Next check IC9 pins 7&8 for 10.695mhz in TX. - very small signal, will only see this with a good scope and switch the probe to x1.
The last troubleshooting aid that can help would be to have a known good DX88 setting on the bench plugged into DC so you can use it
for comparison checks.
8)
-Ray
  #3
Old 11-29-2007, 01:34 PM
Junior Member
Default
Thanks Ray I have done all of that and found everything to be ok. That is what that has me lost the damm thing should be working. Thanks for the help I will keep trying.
73s Hank
  #4
Old 11-29-2007, 01:40 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
I couldn't resist , Very good info and the time it took you to explain it GRTS. Very nice.
  #5
Old 11-29-2007, 05:01 PM
Galaxy Tech
Default
73s Hank
It's electrically impossible to see the values I've posted and not show 10 watts to the wattmeter unless you have bad coax.
Sometimes it's good to just walk away and come back to it again later with an open mind.
  #6
Old 11-29-2007, 08:08 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
I agree if you have all voltages where they should be it has to work it rules out everything from bad caps to resisters I am wondering if you have a weak or spuratic final thats dropping off here and there I seen this once and I reheated the legs on the finals and resoldered them which fixed my issue maybe try that mine would almost completely quit.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
