WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > Tech, & Repair
Notices
Tech, & Repair Before you do anything, read this.! The modifications are not verified and tested by The WorldWide Radio Forum , so if you try some of the modifications, it's on your own risk. Performing modifications of some equipment may be a violation of local laws. If you have any doubts, do not perform the modification.
Reply
  #21 (permalink)
Old 09-06-2008, 07:46 AM
AudioShockwav's Avatar
Senior Member
AudioShockwav is on a distinguished road
Default
Sorry I have not responded sooner....it is crush season here in ca.....
I don`t have the amp in my hands, but looking at the pics it sure looks like the VR right under the relay ( the one with the 2879 sticker ) controls the ssb delay,
i would mark it so you know were you started, give it a small adjustment and see what the result is.....sure looks like it to me. I would try that before ripping out the board to change cap values....just make sure you mark it so you know were you started.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/javagif/gifs_thumb/20080120_1300_eit_171.gif
NASA/SOHO
  #22 (permalink)
Old 09-06-2008, 01:50 PM
Junior Member
grasshopper1031 is on a distinguished road
Default
thanks to everybody who reply and read this post, especially to AudioShockwav, hes right its the vr near the relay that adjust the SSB delay. ive got it now thanks again and 73,s............grasshopper1031
__________________
RF 1031 Alberta,Canada
PresidentHR-2510(Rogerbird Tuned)
Astatic D104M6C
MagnaForce Amplifier
Predator 10k Dual Coil
Yaesu FT-900 CAT
Yaesu FTdx 100
73's...from VE6
  #23 (permalink)
Old 09-08-2008, 04:13 PM
Senior Member
Default
Good deal, now just make sure you keep the drive down on it, and keep it cool, a couple of fans on the heat sink would be the ticket.
__________________
Radio-active
NASA/SOHO
  #24 (permalink)
Old 10-03-2008, 10:16 AM
Switch Kit's Avatar
Senior Member
Switch Kit is on a distinguished road
Default
Very good call on this one Jeff , sure made life a lot easier being a VR . I have a older Blue face Palomar 225 AB-1 (about 12 years old) this amp has no VR to adjust , the problem is that the AM delay is slightly to long.
Now I remember in the past that this was common on some of the first run versions on this amp , beings that there's no VR adjustment , would it be a cap that needed to be changed to fix the problem on the AM side ?
and would SSB be affected if trying to give it less delay on AM ? I'll get a picture up shortly. thanks
  #25 (permalink)
Old 10-03-2008, 10:44 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
I have one of those 'Looks identicle . Just another name on it.
Can any one verify the resistor circled in this picture?
I think it is 100 ohms but not sure.
Mine is a crispy critter and two bad transistors.
  #26 (permalink)
Old 10-03-2008, 11:01 AM
Switch Kit's Avatar
Senior Member
Default
but it looks like yours has the vr for the delay ? unless your referring to something else ? Good luck to you as well.
  #27 (permalink)
Old 10-03-2008, 02:28 PM
Radio Tech's Avatar
Radio Operator
Default
Quote:
Actually I used his picture . My amp is the same as his. I was at work and saw no need to take a picture of mine. And yes mine has a varible delay also.
Mine popped a transistor and took out a resistor. To the point I can not tell what it is. I think by looking at the pic I posted that it looks like a 100 ohm. I circled it in red. I already have a set of transistors to replace with but dont want to risk it and put the wrong value in.
  #28 (permalink)
Old 10-04-2008, 11:11 AM
Switch Kit's Avatar
Senior Member
Default
sorry I didn't see the circle , you can read the color code on the resistor ? or put a meter on it . Resistor Color Code Converter
  #29 (permalink)
Old 10-04-2008, 12:50 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Can't quite make out the colors on the circled resistor, but it doesn't look burned or overheated from what I can see.
If you try to measure it with a meter, be sure to disconnect one end from the circuit. Otherwise you'll be measuring other stuff as well, and that will affect the reading you get.
__________________
No trees were harmed in the sending of this post; however, many electrons were inconvenienced.
73 de K7KBN
  #30 (permalink)
Old 10-04-2008, 01:35 PM
Radio Tech's Avatar
Radio Operator
Default
Ok, Let me refraze this a bit..............
The picture I posted is on of grasshopper1031 pictures, not mine.
I only used it to show the area I was in question of.
My amp has a chard and broke resistor. So no meter will read it and the resistor is so burnt I can not even tell it had color bands on it.
When I saw grasshopper post those I just took one of his and put a circle on it then re-uploaded since his amp is the same as mine. But in his picture it is not clear enough for me to see the colors.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
