| | | Notices | Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar. | | Tech, & Repair Before you do anything, read this.!
The modifications are not verified and tested by The WorldWide Radio Forum , so if you try some of the modifications, it's on your own risk.
Performing modifications of some equipment may be a violation of local laws. If you have any doubts, do not perform the modification. |  | |
07-30-2008, 10:34 PM
| | Junior Member | | Join Date: Oct 2006 Location: ALBERTA, CANADA
| | ELITE LINE TX-5500 hello members can any one tell me how to removed or shorten the ssb delay on this amp( it has auto SSB ) delay switch but delay is way too long. thanks in advanced .......grasshopper1031 Attached Thumbnails
__________________ RF 1031 Alberta,Canada
PresidentHR-2510(Rogerbird Tuned)
Astatic D104M6C
MagnaForce Amplifier
Predator 10k Dual Coil
Yaesu FT-900 CAT
Yaesu FTdx 100
73's...from VE6 |
07-31-2008, 08:13 AM
|  | Senior Member | | Join Date: Apr 2005
| | Damned nice looking amp you got there !!  Wish I could pin point you to the cap that would more then likely need to be lowered or highered in value to get what you needed. So thats' what the originals looked like ! Very nice !!  I would guess on the cap I circled , but IM NOT 100% sure about that.  |
07-31-2008, 02:27 PM
| | Junior Member | | Join Date: Sep 2005 Location: VA
| | i thank itis one of the VR you need to ajust |
07-31-2008, 05:47 PM
| | thanks for the flowers SK., its a nice amp for sure, nice and clean audio especially on SSB. let see what the other amp guru will say, thres too many caps/ vrs to choose from lol, ....grasshopper1031
Astatic D104M6C
Yaesu FT-900 CAT
Yaesu FTdx 100
73's...from VE6 |
07-31-2008, 06:33 PM
| | Quote:
Originally Posted by grasshopper1031 thanks for the flowers SK., its a nice amp for sure, nice and clean audio especially on SSB. let see what the other amp guru will say, thres too many caps/ vrs to choose from lol, ....grasshopper1031 | Good choice.  |
08-02-2008, 04:01 AM
|  | Member | | Join Date: Apr 2008 Location: Cornpatch of Iowa
| | I think the VR's control the biasing. There's an electrolytic capacitor you have to change in the keying circuit to a smaller value to shorten the SSB delay, but unfortunately the picture isn't quite detailed enough for me to tell you which one.
-Exit |
08-08-2008, 03:21 PM
| | Senior Member | | Join Date: Jul 2005 Location: Northern Ontario Canada
| | you more than likly going to be changing cap values. Keying circuits are pretty much the same...automatic or not... your still going to have a cap that holds the relay open for ssb.
I don't have time right now.....I can take a closer look at the pic or dig up a schematic this weekend if you want.
Take care
__________________ Bushwacker-- Bush Station 588... VA3
Bench Tech/Installer
Lakehead Communications |
08-09-2008, 12:57 PM
| | PLEASE do not adjust the VR`s in that amp, they do control the bias, there should be a jumper you remove to check the bias and then adjust it when setting up the amp. The image is too small but there might also be a jumper to allow hi/low drive levels. I am sure Bushwacker can tell you what cap to change.
__________________ Radio-active
NASA/SOHO |
08-09-2008, 01:02 PM
| | Can you post another picture, of the rear of the inside/rear of the Amp?
The Vr`s that are in the heat sinks for the bias transistors are for the bias adjustment. It is hard to tell, but it looks like there is another VR located to the rear that might be there to adjust the SSB delay, but I would like to see a better Pic.
NASA/SOHO |
08-09-2008, 02:44 PM
| | heres some more pics of the inside.
Astatic D104M6C
Yaesu FT-900 CAT
Yaesu FTdx 100
73's...from VE6 |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 04:22 PM. |
