Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar.
Tech, & RepairBefore you do anything, read this.!
The modifications are not verified and tested by The WorldWide Radio Forum , so if you try some of the modifications, it's on your own risk.
Performing modifications of some equipment may be a violation of local laws. If you have any doubts, do not perform the modification.
Anyone ever remove one of these in order to install an echo board??? Any problems with things not working right?? Seems pretty straight forward from looking at the diagrams and appears to not affect the operation.... I could be wrong... Any ideas??
