Astatic #575-M6 Mic Cable Internal Wiring Needed Hello, gang!
I need the interior cable wiring diagram and/or schematic for the Astatic #575-M6 6 wire mic. The cable was ripped clean out from the mic case right from the solder connections inside of it.
I need to find the connections for all of the wires in the cable. A clear pic of the internal mic pcb where the cable wires are soldered would probably be all I need as long as the wire colors are visible at the soldered points.
The wire colors inside of the cable are; red, white, yelow, blue, black & braided sheild.
I apreciate any help I get. Thanks, in advance!
73's to all MrCyber2000 aka Triples Ones aka Operator #11 in the Keystone |
