WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > Tech, & Repair
Notices
Tech, & Repair Before you do anything, read this.! The modifications are not verified and tested by The WorldWide Radio Forum , so if you try some of the modifications, it's on your own risk. Performing modifications of some equipment may be a violation of local laws. If you have any doubts, do not perform the modification.
Reply
  #1 (permalink)
Old 08-17-2008, 04:29 PM
scout943 is on a distinguished road
Default switch
This is going to sound stupid but can I use an on/off volume control switch from an old small transister radio as a plain on/off switch? I want to shut off a 9 volt battery on a microphone when it is not in use, the switch has three tabs for wire connections, if it can be used this way how would I wire it, I just want to put it between battery and microphone on the battery wires its a new switch I have lying around just thought I could put it to use. Thanks in advance Joe K.
  #2 (permalink)
Old 08-17-2008, 08:36 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
The "three tabs" you're referring to sound like they're for the volume control part. If this is indeed a combined on/off switch and volume control, there should be two more terminals for the switch. Use a multimeter to check.
Can just the switch part be used by itself? Sure.
__________________
No trees were harmed in the sending of this post; however, many electrons were inconvenienced.
73 de K7KBN
  #3 (permalink)
Old 08-17-2008, 08:51 PM
Default
I did check with meter,and no matter which of the 3 tabs I check with the switch clicked on or off I still get continuity this switch is ment to be soldered to a circuit board it has 3 tabs plus 1 on each side. I thought the side tabs were just to hold on the board. Thanks for the reply I will check it again. Thanks alot BEETLE
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
