Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar.
Tech, & RepairBefore you do anything, read this.!
The modifications are not verified and tested by The WorldWide Radio Forum , so if you try some of the modifications, it's on your own risk.
Performing modifications of some equipment may be a violation of local laws. If you have any doubts, do not perform the modification.
have a s-3 that will go to channel 9 when turned on in the morning no tx or rx ..flip on off a few fast times if lucky it will work fine as long as you dont turn it off..
